zeusrekning
- Dec 21, 2007
- 448
- 0
Have any of you guys used tungsten for anything. I was wondering if it would work for the heated end of a stirling engine. We make weights at work out of 97% pure tungsten and while sawing the stuff it gets very hot and holds the heat for a while. It is also used for welding electrodes so it will withstand the heat.
Disadvantages:
1: Very expensive. A bar of pressed and sintered Tung. .56" x 1.4" x 12" long cost about $240.
2: Heavy, I think it is 1.7 times the weight of lead. Bar mentioned above is about 6.5lbs. And a 1"dia pc 1" long is about 1/2lb.
It does machine very well. I was surprised because I thought it would be very hard but it is not.
Disadvantages:
