treadmill motor on press drill
Discussion in 'Machine Modifications' started by canadianhorsepower, Mar 28, 2018.
  1. Mar 28, 2018 #1
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Well-Known Member HMEM Supporter
    Oct 22, 2011
    1,671
    320
    This is one of the best mod ever to replace any ac motor
    on press drill, Taig lathe or any mill. Easy cheap and works like a charm.
    enjoy
    the description is pretty clear :thumbup::thumbup:
    bmac2 and akitene like this.
  2. Mar 28, 2018 #2
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Oct 22, 2011
    1,671
    320
    enjoy these new pics
  3. Mar 28, 2018 #3
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Oct 22, 2011
    1,671
    320
    enjoy these pictures
  4. Mar 29, 2018 #4
    el gringo
    el gringo
    el gringo
    Aug 30, 2010
    276
    136
    Gender:
    Male
    Occupation:
    ret
    north west ca adjacent to lake pacifica
    I replaced the original drive on my South Bend 9"fifteen years ago with a treadmill motor and it is still going strong ... nice range and plenty of torque in all speeds. I think I paid $25 US for it at a Salvation Army or Goodwill store.
    canadianhorsepower likes this.
  5. Mar 29, 2018 #5
    bmac2
    bmac2
    bmac2
    Well-Known Member Project of the Month Winner
    Aug 16, 2013
    1,006
    703
    Hi Luc great mod. Treadmill motors have great low end torque and almost scary top speeds.
    Just had a quick look on Kijiji and there are 4 older but supposedly working in my area under $20.00 (2 free) if you come and get them.
    I guess setup and delivery are included in the price but when you get sick of hanging clothes on it you’re on your own to get it up from the basement Rof}.
    One tip I read about picking one up on the cheap was to take along a good cordless screwdriver/drill and a cordless impact wrench. *knuppel2*
  6. Mar 29, 2018 #6
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Oct 22, 2011
    1,671
    320
  7. Mar 29, 2018 #7
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Oct 22, 2011
    1,671
    320
    A few people told me it was wrong to use
    RED as increase
    GREEN as decrease.
    My opinion to this is like a traffic light.
    GREEN is safe
    RED is dangerous
    SO increasing speed could be dangerous to you and the equipment.
    as for the PAUSE button
    it is a {soft slow and a soft increase to the latest RPM use}
    the Panic button will stop the motor power instantly
    IE{if your material wants to jam on you the motor is OFF instantly
    compare to a pause it will slow down evenly
  8. Mar 29, 2018 #8
    Wizard69
    Wizard69
    Wizard69
    Mar 9, 2013
    1,356
    270
    People will say things that are perfectly true where they are but may be wrong in your location. The standards for industrial controls vary widely country to country as does enforcement. There is effort afoot to standardize pushbutton coloring but uptake seems to be slow.
    Red is pretty much reserved for E-Stops these days. It use to also be the stop button for motor on/off circuits. Generally you don't want to use RED for anything other than E-Stops these says.
    Unfortunately traffic controls are another standard one that is surprisingly well adopted world wide.
    Generally you want an E-Stop to kill power, often by a Master Control Relay, so that the machine can be powered down if an electronics failure is the cause of the panic.
    An interesting aside just last night i had a mold machine go down at work. One stuck switch on the keypad put the controller into an odd state where some things worked and some didn't leaving an extruder running. Having an E-Stop prevented a huge mess from forming. This was nothing more than old age but it highlights how even professional done controls can end up not responding to the user. Thus the need for an E-Stop circuit that is independent of the controller.
    In any event a great post with excellent pictures. Id be very interested to hear how this drive does at very low speeds, say 40-60 RPM on the spindle. Think running large hole saws into steel where you want to keep SFM down
    It is good to see another move into the variable speed camp. Once you have the ability you never look back.
  9. Mar 29, 2018 #9
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Oct 22, 2011
    1,671
    320
    Hi Ill be more than Happy to post a video with 40 RPM and a hole saw. Thanks for the comment.
    video to come
  10. Mar 30, 2018 #10
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Oct 22, 2011
    1,671
    320
    here is the video
    https://www.facebook.com/luc.gyre/videos/10211818626396832/
  11. Mar 30, 2018 #11
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Oct 22, 2011
    1,671
    320
    slow RPM in aluminium.
    no shattering very steady
  12. Mar 30, 2018 #12
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Oct 22, 2011
    1,671
    320
    [QUOTE
    It is good to see another move into the variable speed camp. Once you have the ability you never look back.[/QUOTE]
    I did one with 1/4 alu perfect
    here is another one enjoy
  13. Mar 30, 2018 #13
    Wizard69
    Wizard69
    Wizard69
    Mar 9, 2013
    1,356
    270
    Thanks for the pics/videos!
    I have a drill press that needs rebuilding ( bad spindle run out) and will consider a variable speed solution when the time comes. Time is the big issue though, to many house maintenance projects in flight at the moment.
  14. Mar 31, 2018 #14
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Oct 22, 2011
    1,671
    320
    you are welcome:thumbup:
    I don't know you're electronic background,
    need any help................simply drop a line ;)
    Luc
  15. Mar 31, 2018 #15
    abby
    abby
    abby
    Apr 14, 2009
    401
    114
    I did my conversion three or four years ago . My wife had stopped using the treadmill in favour of the Wii , which , being connected to the TV , is in more salubrious suroundings than my workshop.
    I decided to reclaim my work space by dismantling and scrapping the now redundant gym kit.
    The DC motor after a little teasing with a hacksaw fitted on the back of my BCA jig borer like it was meant to be there,
    [​IMG]
    the guts of the speed control I managed to fit into the case of scrap welding inverter I had been given ,
    [​IMG]
    The speed of the treadmill was operated by a sliding pot which I replaced with a similar value rotary unit to replace the one on the inverter case,
    [​IMG]
    The set-up has been in use daily , sometimes for several hours with no problems , and the amount of power available from such a compact motor is amazing (to me).
    The only thing I would change in retrospect is the soft start on the motor , the potentiometer has to be turned to zero before selecting speeds.
    Dan.
    RM-MN likes this.
  16. Mar 31, 2018 #16
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Oct 22, 2011
    1,671
    320
    you can solve that issue
    HTML:
    by simply cut the power to the motor
    { one on/off switch on the motor only}
    . It will act as a "pause'" but
    the soft start will be a little faster then the one I design.
    that would be the same set up I'm using on my Taig Lathe.
    If you want to go one step further {Idid} use a DPDT switch
    and the will give you CW and CCW rotation pretty neet set up
    for tapping
  17. Apr 1, 2018 #17
    Wizard69
    Wizard69
    Wizard69
    Mar 9, 2013
    1,356
    270
    Actually i work automation at work and do well with the controls. Figuring out how to do a new drill press spindle is a bit more of a challenge.
  18. Apr 1, 2018 #18
    nautilus29
    nautilus29
    nautilus29
    Jun 12, 2017
    74
    11
    Thanks for the post! I've been considering doing this to my taig lathe, but I wasn't sure if the treadmill motor would handle it.
    Could you post the specs on that treadmill motor?
  19. Apr 1, 2018 #19
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Oct 22, 2011
    1,671
    320
    this is the motor plate.
    My Taig already had that mode done to it LOVE it
  20. Apr 1, 2018 #20
    nautilus29
    nautilus29
    nautilus29
    Jun 12, 2017
    74
    11
    Did you keep the original pulleys on your taig or make new ones? I notice the rpm is significantly higher than the motor that comes with the lathe.
Draft saved Draft deleted
Share This Page
Group Builder
