Tool Post grinder for a Myford ML7
Discussion in 'Buy / Sell / Trade' started by Bill East, Oct 31, 2019.
  1. Oct 31, 2019 #1
    Bill East
    Bill East
    Bill East
    New Member
    Aug 27, 2019
    3
    0
    Gender:
    Male
    Australia
    Hello people
    I am looking for plans etc for a tool post grinder that will be used for model aircraft piston and liners.
  2. Oct 31, 2019 #2
    goldstar31
    goldstar31
    goldstar31
    Feb 20, 2010
    2,416
    543
    Gender:
    Male
    Occupation:
    Haggis Breeder
    Twixt Tyne and Tees
    Recently I was communicating with Frazer( Fcheslop) about tool and cutter grinder projects and suggested that a wood router had been used in the Brooks design ( MEW16 and 17).
    My setup is quite archaic and uses a Bosch POF 50 with a 43 mm collar.
    However, I trust that your Myford ML7 will still hold tenths of thous as there seems to be little purpose to try to grind to fine limits with sloppy slides and feed screws. You will note that there is a considerable correspondence on lapping as a alternative.
    I hope that this is constructive
    Norman
  3. Oct 31, 2019 #3
    Charles Lamont
    Charles Lamont
    Charles Lamont
    Mar 24, 2011
    606
    160
    UK
  4. Nov 1, 2019 #4
    Bill East
    Bill East
    Bill East
    New Member
    Aug 27, 2019
    3
    0
    Gender:
    Male
    Australia
    Many thanks to Goldstar31 and Charles Lamont for your suggestions. My lathe is in quite a good condition and suffered only minor damage compared to the mill in the moving process. My parents purchased it from a classified ad for my 12th Birthday. Many parts for model aircraft have been made on the Myford including the whole front end for high-performance power models, I will, however, check the Cross-Slide, etc. before making a decision.
    The Hemingway grinder seems very large and appears cumbersome, almost out of place on a Myford. The router idea, however, has some merit that I will pursue.
  5. Nov 2, 2019 #5
    goldstar31
    goldstar31
    goldstar31
    Feb 20, 2010
    2,416
    543
    Gender:
    Male
    Occupation:
    Haggis Breeder
    Twixt Tyne and Tees
    Deleted
  6. Nov 2, 2019 #6
    WOB
    WOB
    WOB
    Sep 12, 2013
    193
    36
    Bill, I think you will be disappointed trying to make model diesel( my assumption) pistons and liners by tool post grinding. It just isn't going to happen with hobbyists grade machinery. The fits are too critical and the dimension control is not nearly good enough.
    Lapping with diamond abrasives allows you to sneak up on the correct fit and also leave the correct surface finish. Homemade laps are easy to make on the lathe and diamond lapping compound is not that expensive.
    If you are determined to have a tool post grinder for your ML7 , I would suggest making a tool holder for one of the flex shaft handpieces such as those that Foredom makes. They are available up to 1/3 HP and variable speed( essential). The hand pieces are available with collets and have very good ball bearings. No doubt there are various import clones. Foredom is expensive but top of the line quality and will last a lifetime.
    WOB
Draft saved Draft deleted
Share This Page
Group Builder
