Had some time to work on my Cusader WIP and decided to machine the last crankcase. Since I had broken my last insert in my boring bar I tried a brazed bar from my boring head. Worked OK but I had to keep depth of cut to .020.
Now the problem.
I had built up enough swarf to make a rather large pile in the lathe bed. While I was taking a cut the swarf was getting packed in the hole. I removed it each time but it was a consistent problem.
Titanium will burn. It will burn white hot and very quickly.
I had a small piece of swarf start up and when it came out of the bore it landed in the lathe bed. Reference the contents of the lathe bed previously and you will see a nice little bed of material to continue the the fireworks!
I rushed outside and was able to get some sand (one of the benefits of desert living) and smother the fire. :-[
Two things learned:
1.) Understand the properties of what you are machining. I know that titanium is flammable but hadn't had a problem. I should have had the sand next to the lathe to begin with to avoid the panicked rush outside!
2.)Clean the lathe bed when working with a material of this type!
Hope this helps someone,
Sean
Now the problem.
Two things learned:
Sean
