Hello all.
I am looking at building up a Yarrow designed boiler. If you haven't seen one of these, then a simple GA is here:
http://www.modelengines4fun.com/postDetail/5/
However, I am planning to use only two sets of tubes, rather than three.
I have a few questions I was hoping someone could give me some thoughts about?
1) - Soldering the tubes to the lower water drums.
This will be a completely "blind" joint - I won't be able to see into the drum at all. I've not built like this before, and I'm not sure how I can make myself confident that all the joints are good. I won't be able to see penetration through the joints. This is going to be a fairly high pressure system, and while of course it will be hydro-tested first, I still want to be happy with the joints over time.
2) Again on the down comer tubes into the lower water drums - the design books I have show that the down-comers are flush with the drum. By this I mean that they do not project into the drum at all. I feel that it will make for a stronger joint if there is perhaps 2-3mm projection. It might make for a stronger joint, and will add a ( small ) element of baffling to what is going to be a very turbulent system.
Can anyone let me know if I might be making problems for myself by doing this?
3) All the design notes I have refer to the fact that I need to put baffles in the main water drum to control turbulence at the top of top of the tank in order to stop water pick-up with the steam collection, but not a single reference describes these baffles in any detail. Can anyone point me at any references to baffles boilers, or give me some thoughts?
Many thanks
Alf
Many thanks
Alf
