The Beginning of another I. C. Engine,
Discussion in 'A Work In Progress' started by DavidLloyd2, Jun 16, 2017.
Help Support HMEM by donating using the link above.
  1. Jun 16, 2017 #1
    DavidLloyd2
    DavidLloyd2
    DavidLloyd2
    Jul 17, 2016
    58
    67
    ------------After Building Brian Rupnows vertical I. C. engine and being please with that engine I decided to have a go at Brian's Rockerblock I. c. engine.
    So I started on the two side plates
    Two Days workshop time I have two side plates ,
    To be continued.
    DavidLloyd
    Cogsy, michael-au, Rickl and 2 others like this.
  2. Jun 16, 2017 #2
    Cogsy
    Cogsy
    Cogsy
    Well-Known Member Global Moderator
    Jul 30, 2012
    2,038
    576
    Gender:
    Male
    Looking good. I'll be following along. Are you building it in metric (I ask because of the NSK bearing)?
    Rickl likes this.
  3. Jun 16, 2017 #3
    DavidLloyd2
    DavidLloyd2
    DavidLloyd2
    Jul 17, 2016
    58
    67
    N Z is metric and all the stuff I am buying is in metric
    Drawing for the side plates call for .375 material I am buying and using 10mm,
    NSK Bearing I got are mm: 6001DDUCM 1605 NS7SI 12mm ID
    Nut and Bolts call for imperial I will be using mm
    DavidLloyd
  4. Jun 16, 2017 #4
    Brian Rupnow
    Brian Rupnow
    Brian Rupnow
    Well-Known Member Project of the Month Winner
    May 23, 2008
    10,377
    3,132
    Great stuff, David. I will be following closely.---Brian
  5. Jun 16, 2017 #5
    bruedney
    bruedney
    bruedney
    Nov 16, 2014
    70
    16
    Gender:
    Male
    Looking good Dave - James (Joco) and I will have to pop out and have a cuppa to see the progress
    Bruce
  6. Jun 16, 2017 #6
    Herbiev
    Herbiev
    Herbiev
    Administrator Staff Member Administrator Moderator Global Moderator
    Jan 6, 2011
    2,306
    292
    Looking good David. I'll be following your build too
  7. Jun 17, 2017 #7
    Brian Rupnow
    Brian Rupnow
    Brian Rupnow
    May 23, 2008
    10,377
    3,132
    Strangely enough, I designed it for metric bearings because I had a pair of sealed 12 mm bearings I had saved from something I tore apart. However, that was the only really metric part. Of course the crankshaft had to be partly metric to suit the bearings, and the bore of the small gear, ignition cam, and flywheels had to be metric to match the crankshaft. I can work in metric, but I'm not really comfortable with it. I was in my mid to late 20's when some fool decreed that Canada would become a metric country. I had to work in metric after that for 10 or 15 years, but Canada slowly transitioned into a permanent haze of semi metric/semi British Imperial (inches). I reverted back to the old system I learned 65 years ago in the public school system. Now that I design ****e mostly for fun, I don't do metric unless I really have to.---Brian
  8. Jun 20, 2017 #8
    DavidLloyd2
    DavidLloyd2
    DavidLloyd2
    Jul 17, 2016
    58
    67
    Good Day and Time for a up-date and some photos
    I have completed the Rocker Post and the bolt down plate,
    I will make the cylinder head end next to keep the frame together.
    I do like the 4 jaw self centering chuck on a rotary table Ideal for quick setup for doing the radius on top of the Rocker post,
    DavidLloyd
    Rickl likes this.
  9. Jun 20, 2017 #9
    MariusTitulescu
    MariusTitulescu
    MariusTitulescu
    Junior
    Jun 16, 2017
    5
    1
    Looking great, man! Keep it up!
    DavidLloyd2 likes this.
  10. Jun 28, 2017 #10
    DavidLloyd2
    DavidLloyd2
    DavidLloyd2
    Jul 17, 2016
    58
    67
    I spent most of my time working in my cold work-shop on the cylinder head end of the frame.
    Three Excellent Drawings got me through that no problems.
    Cylinder is made from cast iron and the Bolster- Tappet Guide is from bronze,
    DavidLloyd
    minh-thanh likes this.
  11. Jun 28, 2017 #11
    Brian Rupnow
    Brian Rupnow
    Brian Rupnow
    May 23, 2008
    10,377
    3,132
    Beautiful work David. I find it absolutely thrilling when someone else builds one of my engines and documents it.---Brian Rupnow
  12. Jun 30, 2017 #12
    doubletop
    doubletop
    doubletop
    Mar 1, 2010
    857
    76
    Nice!! You will have to bring it along on Wednesday
    Pete
  13. Jul 20, 2017 #13
    DavidLloyd2
    DavidLloyd2
    DavidLloyd2
    Jul 17, 2016
    58
    67
    Some Progress being made in the last two weeks
    I have never made a Built up crankshaft and con rod this way
    Thanks to Brian's excellent instructions on the crankshaft drawing all went together good,
    DavidLloyd
    bruedney, Parksy and minh-thanh like this.
  14. Jul 20, 2017 #14
    Brian Rupnow
    Brian Rupnow
    Brian Rupnow
    May 23, 2008
    10,377
    3,132
    Great work. I am following with great anticipation.---Brian
    hedgehog likes this.
  15. Jul 27, 2017 #15
    Brian Rupnow
    Brian Rupnow
    Brian Rupnow
    May 23, 2008
    10,377
    3,132
    David--What happened to your build? I tune in every day looking for progress, but nothing is happening. I hope all is well.---Brian
  16. Jul 29, 2017 #16
    DavidLloyd2
    DavidLloyd2
    DavidLloyd2
    Jul 17, 2016
    58
    67
    Brian
    Making cams is not one of my favorite things to make Hopefully by the end of the day I will have two cams that I will be satisfied with and move on to the flywheels,
    DDT_5607.jpg Tow modified gears
    DDT_5604.jpg Making Cams
    DavidLloyd
  17. Jul 29, 2017 #17
    Brian Rupnow
    Brian Rupnow
    Brian Rupnow
    May 23, 2008
    10,377
    3,132
    Thank you David. Cams are not one of my favourite things to build either.---Brian
  18. Aug 6, 2017 #18
    DavidLloyd2
    DavidLloyd2
    DavidLloyd2
    Jul 17, 2016
    58
    67
    The Month of August in New Zealand being Cold Time in the workshop is limited
    But some progress.
    Brian after no response from trying to locate a water jet company in Wellington I have committed to do the flywheels myself
    Parts to add to the Rockerblock,
    DavidLloyd
    minh-thanh, Parksy and Rickl like this.
  19. Aug 6, 2017 #19
    Brian Rupnow
    Brian Rupnow
    Brian Rupnow
    May 23, 2008
    10,377
    3,132
    Great stuff, David. Thank you so much for the pictures. I spent a lot of time and money on my water-jet cut flywheels, and although they are quite remarkable when setting still, you can't see how fancy they are when the engine is running anyways.---Brian
  20. Aug 12, 2017 #20
    DavidLloyd2
    DavidLloyd2
    DavidLloyd2
    Jul 17, 2016
    58
    67
    First cuts
    One flywheel one to go
    Two flywheels and one starter hub
    And a Flywheel puller,
    DavidLloyd
    Buchanan, Parksy, bazmak and 3 others like this.
Share This Page
