Tin Falcon
- Jul 9, 2007
- 7,207
- 787
Guys here is the proposed plan look it over for any flaws I want to get the addresses you need to you soon.
The goal is to have parts in transit by the middle of June if you have your parts complete you may send them as son as I get you the addresses you need.
Team build April June 2008
Elmers Open Column
(1)(TC) Brass_Machine- 6 sets Piston /Cylinder/flange/Wrist pin (6)
Send #2, 3 each of parts made, and 3 each bases from # 9
Send # 9 a kit of all parts less base
Send #3- 8 bases from #9
(2)(TC) Tin Falcon -reversing valve, Reversing valve stud
Send # 1, 3 each bearing block from # 10, and 3 each of parts made
Send # 10 a kit of parts less bearing block
Send # 3- 8 ,1 each of parts made.
(3) Deer-x475guy - steam connector /Piping w/ flange
Send 3 of each part to #1 & #2 and 1 ea to # 4 - 8
(4) Zeusrekenining - 6 sets Piston /Cylinder/flange/Wrist pin (6)
send 1each to # 3 and 5-8
(5) Jadecy 6 ea bearing blocks
send 1 each to 3,4 and 6-8
(6) Bob_Warfield - Brass fly wheels & con rods
send 3 each to #1 & 2
send 1 each to 3-5 & 7,8
(7) Powder Keg - Columns 4-40 internal thread w/ bling
Send 3 sets of parts to 1 & 2
Send 1 set of parts to 3-6 & 8
(8) GailinNM -Crank shaft . crank disc, crank screws
(9) Gilesm - bases- plus wood sub base
Send 11 Parts to #1 Receive kit from #1
(10) Joe D - 6 bearing blocks
Send 5 made parts to #2 receive kit from # 2
Elmers Open Column
