TB 3 Regulators
joe d
Hi all
I'm doing the regulators and points for this one, so I've started with the regulator yokes as they are the most complex part I have to do in terms of number of operations required....
Blanks cut, faced, turned to size, bored, and counterbored
all the "straight" milling done
16 of the beggars... got about an hour and a half in each one so far
Now, it's on to the rotary table.....
Cheers, Joe
Progress....
Milling away excess material on the rotary table:
milling done, drill and tap hole for retaining set screw (with my shiny new sensitive tapping device, thanks Marv and others who have posted such things.....)
Parted off, ears rounded, just got to clean up the machining marks and shine it up a bit: only 15 more to go!
Stay tuned, more to come...
Cheers, Joe
Progress....
sanded, sanded, sanded, and polished. 14 more to go....
Joe
Hi all
More progress to report....
cut out a bunch of brass blanks for the regulator arms,some drilling, milling, and one tapped hole each
cut away the excess material
Using a fixture on the rotary table to round over the ends
All done....
Installed in the yokes
Stay tuned, more to come.....
Cheers, Joe
I love progress pics!
you did all this on a Taig?
very nice work!
I wish I had the machines and skills so I could participate in a team build with an IC engine.
IC's are soo interesting to get a little thing to come to life like the real thing!
but even if you dont have machines, pictures like the ones you posted give you an exited feeling :D
Speedy
Thanks for the compliment. As to participating, yes you need the machines, but once you get over that hurdle the skills will come... 3 years ago my metal working tools were a BFH, some files, and a hacksaw with a dull blade......
I'm very happy with the Taig equipment, it's done everything I've asked of it so far. Not to say that it wouldn't be nice to be able to turn that 12" dia flywheel, but I don't really need to do that very often so far :big:
Cheers. joe
Beautiful parts Joe! :bow:
As for the "BFH", mine is a 20 pounder. It's great for
instant gratification when things don't quite go to plan.
Rof}
Rick
Excellent craftsmanship achieving superb parts!!! Thm: Bravo Zulu.
Andy
Dang near done....
Been working on the weights for the regulators. Turned and counterbored a fixture for the lathe:
I precut all the blanks, and drilled the mounting holes, attached the blank to the fixture, centredrilled, removed the capscrews and held the blank with a centre for facing:
After turning to OD, drilled and bored for ID:
Once they were all done, drilled them all for the pins for the springs, then I milled a flat on my fixture to hold it in the vice on the milling machine to separate them into two pieces
And here we are with some of the pins installed:
I neglected to measure the the brass rod I used for the pins against the size of the drill I used for their holes.... so all the pins are being sweated into place as they are a little too loose for just loctite. Oh well, I guess I need the practice soldering.... and next time I'll remember to check! Once these are all done and polished, it's on to the springs, which will be another first for me.
Cheers, Joe
Nice job, they look superb! and the finish work is outstanding!
I can see them spinning and flinging now.
Great work Joe . looks like you put some hours in there :bow: :bow: :bow:
Rob
Thanks Rob. Yeah, theres an hour or two in this project so far...
Started winding springs. I've got a Taig lathe with the factory 5-step pulley belt drive. This give me a minimum speed of 500 rpm, way too fast for spring winding (or so it seems to me, as I've never previously done this) so, broke out the old hand drill... made a mandrel with a .02" hole in it to trap the start of the winding, pinched the music wire with some sacrificial brass strips in the vice jaws, and rested the mandrel in a groove in a bit of scrap aluminum on top of the jaws and started winding. Danged if it didn't work!
Starting winding:
Halfway:
Done:
Bunch of them done, just got to trim to length and form the eyes:
Conveniently, SWMBO is leaving for a trip to Michigan with her Mom in the morning... so I can heat-soak the springs in the kitchen oven with-out getting caught :big:
Cheers, Joe
