well the 30 heads for the valves are now done..........what a neat little part to do.
the first pic shows the valve seat being cut with a lathe tool ground to (roughly) 45 degres.
center drilling for the valve stem hole
reaming valve stem hole to 3/32"
parting off
cutting groove in valve stem for the valve spring retainer clip. note the groove is .020" wide
this next pic shows a valve almost completed ......it just has to have the valve stem silver soldered to the head.
the last pic shows what 30 valve heads look like..............not much to show for 1 1/2 hours worth of work
the valve heads are made out of cold rolled steel and the stems are made out of drill rod, they should be all done by the week end and then it is on to the valve keepers and then the cylinder heads.
i have built several engines over the years but never one from bar stock or a team build, so far i'm really stoked about this whole project ;D i can't wait to see all the other bits and pieces for this project!!!!
chuck
hav'in waaayyy too much fun :big: :big:
