Hello Tin and Harry,
thank You for Your replies. A friend of mine has started building a 7 1/4" garden railway (with some help from me) and after two waggons we are currently working on a model diesel engine. Well, to be correct its a gasoline engine (used lawn mower engine) with hydrostatic propulsion, so its design wasn't a real complex task.
Designing a steam engine is nothing I feel competent for, so we have to rely on a reliable plan set for this.
You are right, Tin, its 1:8 scale, thats what You call 1.5" to a foot, for me a very strange designation
In general, we are also willing to buy a plan set for a loco if it looks like good quality. We are at present just in the planning stage for steam; looking around what might be doable for us. Any links to plans, free or commercial are very welcome. I haven't found any German plans for this scale yet, so we have to look for plans outside Germany.
It would be very desirable to get plans in metric; my collection of imperial taps is very limited and I don't own a single drill bit or reamer in imperial size. Also the acquisition of imperial raw material is a difficult task, at least its pretty expensive here compared to metric stuff.
Therefore I am in doubt whether an expensive imperial set of drawings is worth the money
Metrification of all drawings is a huge task and for sure a potential source for new errors, while doing it in imperial will increase costs for material and tools probably twofold or more.
Your link, Tin, to KVOMs build is very interesting, thank You. I will study it in detail.
There are still a number of unsolved questions for us:
1. boiler fabrication
From this and other websites I've learned that most model engine boilers are manufactured by silver soldering.
I must admit my experience with soldering is low, and not always successful
What are the reasons model builders obviously don't weld their boilers? Thats a technique I am much more comfortable with, stick welding, MIG welding. A bit experience with TIG welding has that friend of mine too.
If soldering is essential for the boiler, we will have to look for someone willing and capable of doing this for us.
2. mass of a 7 1/4" engine
While dimensions can easily be estimated by the scale, its much more difficult to estimate the weight of such a project. Is my estimate of 400-800 lbs realistic?
That would be fine for my shop crane (~1100 lbs capacity), I could handle the complete engine with it
3. tools and machines needed
Probably KVOM could tell me a lot more about what he has used for his project (and maybe missed a lot). Is a CNC mill desirable/necessary? I don't have one
What size machines and tools are at minimum necessary?
Mike
