- Sep 2, 2011
- 1,342
- 360
was considering trying to make some of my own springs instead of buying them and have a question.
when it calls for something like 10 coils per inch on your spring would you setup your lathe for threading and go by the chart for 10 threads per inch? and I guess trial and error on the expansion of the diameter that will occur when the tension is take off the wire that you wound around the rod or is there a rule of thumb like .005 smaller rod than the actual inside diameter of the spring you want to make or something?
thanks in advance.
Bryan
thanks in advance.
Bryan
