Generatorgus
Senior Member
- Feb 25, 2010
- 362
- 166
I'm very embarressed about this because it happened to me, two days ago. Maybe my posting it might help prevent another such accident.
I was preparing my camper for the trip to Cabin Fever this coming Friday.
Getting the propane gas systems purged of air and test firing the stove, furnace and combination gas electric refrigerator.
As usual, I start with the stove, which is furthest from the supply and is easier to light. Stove purged I moved to the furnace. This item as well as the refig. will eventually fire up when they are turned on.
The furnace checked out OK and on to the refrigerator.
As mentioned the refrig. has a gas or electric system. The electric part (110V) was working fine, but I saw no fire thru the not to user friendly peep hole at the gas burner, when it was switched to gas.
OK, get some tools and multi-meter.
I tested some of the 12V components and it "seemed" that the solenoid operated gas valve was not getting power. In my own defense, I'll state first that the swicth is also not too user friendly, it's one of those in/out push buttons and is dark brown in color, and not too easy to tell if it is in or out. I thought I turned it off. I'm sure, by now, it's fairly apparent what comes next.
If you guessed "he probably loosened the gas compression fitting to sniff test for gas flow" you win a cigar, an exploding cigar.
As I was bending in the compartment, it went PHOOM, and immediately burst into a rather large fire, inside the compartment.
Not even wondering about my physical condition, my first thought was get a fire extinguisher from the garage about 15 yards away I was starting in that direction when the little voice said "turn the gas off first".
I ran around the camper and closed the gas valve , which seemed an eternity, and the ran back around, which also would be the direction of the garage, and the large flame was gone. The only flame left was a small flame on the now, almost non existent, plastic condensate drain which I simply blew out.
I went and got the fire extinguisher anyway and stood fire guard for about 15 minutes while I surveyed the damage. Fortunately the damage was very minor, the plastic on two connector plugs was damaged, as well as the insulation on one of the wires. Which I easily repaired while I was still keeping a wary eye out for fire.
After what I considered an appropriate amount of time I tested the unit again, and it was working just fine.
I decided that honesty would be the best policy and go confess my stupidity to my better half. I didn't get a word out before she loudly exclaimed, "WHAT HAPPENED TO YOUR BEARD"?
"Nuff said,
GUS
Afterthought, there was a fire extinguisher right near the door in the camper.
"Nuff said,
GUS
