Small steam engine
Discussion in 'Plans' started by dennisa49, Dec 13, 2017.
Help Support HMEM by donating using the link above.
  1. Dec 13, 2017 #1
    dennisa49
    dennisa49
    dennisa49
    Jan 4, 2014
    56
    7
    Hello, I would like to build a small steam engine to fit in a model of a tugboat.
    I was sure I had seen plans on the site, can’t track them down though.
    The engine would need to be no bigger then 50mm x 50mm externally. However a smaller engine would wonderful if possible.
    Any link or suggestion would be much appreciated.
    Thank you and regards,
    Dennis :)
  2. Dec 14, 2017 #2
    bmac2
    bmac2
    bmac2
    Aug 16, 2013
    890
    570
    Hi dennisa. I feel like this is the standard answer to the “small steam engine plans” question but you could check out John Tom’s site http://www.john-tom.com/html/SteamPlans.html probably something on there you could use. In the section with Elmer Verburg Engines http://www.john-tom.com/html/ElmersEngines.html there is a small Open Column with reverse that might work for you. The plans are imperial but the base plate is only 2 7/16” (61.9mm) x 1” (25.4mm)
    http://www.john-tom.com/ElmersEngines/03_openColumnRev.pdf
    bazmak likes this.
  3. Dec 14, 2017 #3
    bouch
    bouch
    bouch
    Dec 17, 2013
    77
    28
    Ray Hasbrouck designed a small 2 cylinder engine for such a purpose. The advantage of his design is that you can switch from full forward to full reverse by moving the reverse lever only 90 degrees. Perfect for RC servos to reverse the engine.
    It might be a little large for your purposes, but I've seen people shrink his designs.
    You can find the design in a book from Village Press, (and also available on Amazon)
    https://secure.villagepress.com/store/items/detail/item/2612
  4. Dec 14, 2017 #4
    fcheslop
    fcheslop
    fcheslop
    Apr 7, 2010
    619
    121
    The land of the Prince Bishops
    Recently made this 3/8 bore and stroke DA twin from Malcom Beaks drawing they canbe found on the Paddleducks site. The engine is known as the MB22
    http://www.homemodelenginemachinist.com/showthread.php?t=26845
    [ame]https://www.youtube.com/watch?v=S38lMY7FZv0[/ame]
    [ame]https://www.youtube.com/watch?v=BXyvAvKezWo[/ame]
    bazmak likes this.
  5. Dec 14, 2017 #5
    dennisa49
    dennisa49
    dennisa49
    Jan 4, 2014
    56
    7
    Thanks for the info.
    John-Tom’s site is very helpful.
    I need to scale the boat design up a little to accept a slightly
    bigger engine. No real problem there.
    It is good to receive informed advice,
    regards, Dennis
    bazmak and charlesfitton like this.
Share This Page
