Superfast
- Aug 25, 2008
- 19
- 0
Alright here goes the experiment. As may of you have seen, I built a smaller version of Chuck's Horizontal engine, a 2 cycle version. There is some pics and video of it in the Photos section. Now I am attempting to make a flyweight governor for it, very similar to what is on a hit or miss engine. The governor required me to build new flywheels, crank shaft and of course the governor itself. Here is a pic of the parts built so far. The flywheels are 2" dia made from steel, turned on the lathe then drilled using a rotary table on the mill. The crankshaft is also steel and silver soldered together. The rest of the parts are all brass and the hardware used is 0-80.
<a href="http://scottsrc.com/machining/newparts.jpg"><img src="http://www.scottsrc.com/machining/thumbs/newparts.jpg"></a>
Now for the governor parts detail, shown next to a penny for size reference. This picture shows the governor assembled without the flywheel. The 0-80 cap screw you can see on the right hand side that is inline with the shaft is the "cam" that operates the valve linkage. With the weights "in" like shown, the cap screw will engage the linkage.
<a href="http://scottsrc.com/machining/governor1.jpg"><img src="http://www.scottsrc.com/machining/thumbs/governor1.jpg"></a>
This view shows the weights in the "out" position, the fingers move the cap screw away from the valve linkage and eliminating the "hit". The 2 small steps cut in the brass center piece are for the linkage fork and will keep it in correct alignment when the cam is pulled away.
<a href="http://scottsrc.com/machining/governor2.jpg"><img src="http://www.scottsrc.com/machining/thumbs/governor2.jpg"></a>
Here are a few detaill shots of the governor being assembled on the new flywheel.
<a href="http://scottsrc.com/machining/governor3.jpg"><img src="http://www.scottsrc.com/machining/thumbs/governor3.jpg"></a>
<a href="http://scottsrc.com/machining/governor4.jpg"><img src="http://www.scottsrc.com/machining/thumbs/governor4.jpg"></a>
<a href="http://scottsrc.com/machining/governor5.jpg"><img src="http://www.scottsrc.com/machining/thumbs/governor5.jpg"></a>
Here are is the governor installed on the flywheel showing the same action as above:
<a href="http://scottsrc.com/machining/governor6.jpg"><img src="http://www.scottsrc.com/machining/thumbs/governor6.jpg"></a>
<a href="http://scottsrc.com/machining/governor7.jpg"><img src="http://www.scottsrc.com/machining/thumbs/governor7.jpg"></a>
I am getting closer to trying this out, but still need to come up with some small springs to use on the weights. I may even try to test it using some small rubber bands.
Scott
Scott
