Nikhil Bhale
Hello,
I have a Sieg C4B lathe. It is similar in size to Sieg SC4 lathe but it has a AC reversible motor and belt and pulley system for speed control.
For slow speeds/ back gear the lathe uses a toothed belt of 1.5mm pitch. This belt is "delicate" and gets damaged easily and is very difficult to source locally.
I am thinking of changing the drive to a DC motor drive.
I have seen people on YouTube and elsewhere using a treadmill motor for this conversion.
After searching on the internet I have two motor options.
1. Treadmill motor DC 180V, 1-1.5kW
2. Ebike motor DC 48V, 1kW
I want to ask which motor will be more suitable?
Both motors cost nearly the same and the controllers for the motor are also in the same price range.
Do we need a separate cooling arrangement for the motors as they may run at less than optimal speed for a long time?
The low voltage ebike motor will draw more current than the treadmill motor. Will this affect anything?
I will add that my "workshop" is not air conditioned and the temperature at my place goes to 47-48C during summer. I generally avoid working in this high temperature but I try to work if temperature is 40-42C.
Nikhil
Nikhil
