Shrink Rule
TNvolute
I have uploaded a PDF of a 1/8" per FT shrink rule with an explanation for its use to the downloads section. I am making a pattern for a T-Slotted slide for my lathe that I hope to get cast at one of the areas small iron foundries. I'm in no physical shape to be a sand crab so I can't see laying out the $s for a tool I will rarely use. If other sizes are needed, let me know as it is pretty easy to do.
What kind of lathe is your T-slot slide designed for? If others are interested (like me!), maybe you could get a batch deal. Where in TN are you? I'm near Kingsport.
Chuck
It's an 11x36" Sheldon. I'm a little below Athens, a bit more than 1/2 way between Knoxville and Chattanooga.
