Short Video showing how to shape a hex head on a SHCS
Discussion in 'Tips and Tricks' started by cfellows, Oct 17, 2014.
  1. Oct 17, 2014 #1
    cfellows
    cfellows
    cfellows
    Well-Known Member Project of the Month Winner
    Aug 26, 2007
    3,891
    697
    retty self explanatory. I quick and dirty way to grind flats on a socket head cap screw turning it into a hex head bolt. No special equipment required, just a small machinist vice, an Allen wrench and a belt grinder or bench grinder with a suitable tool rest.
    [ame]https://www.youtube.com/watch?v=qL2_MwyTYTQ&feature=youtu.be[/ame]
    Chuck
  2. Oct 17, 2014 #2
    crueby
    crueby
    crueby
    Project of the Month Winner!!! Project of the Month Winner
    Mar 9, 2010
    594
    693
    Neat technique - sure it will come in handy - thanks!
  3. Oct 18, 2014 #3
    ShopShoe
    ShopShoe
    ShopShoe
    Senior Member
    Oct 2, 2010
    867
    146
    Thanks Chuck,
    Now I don't have to get out the collet block and set up the mill to do this.
    --ShopShoe
    spurgear likes this.
  4. Oct 19, 2014 #4
    vederstein
    vederstein
    vederstein
    Must do dumb things....
    Feb 26, 2011
    560
    396
    Chuck,
    That's a great technique.
    As far as I can see, if you're making a true model (meaning a replica of an existing design to some scale) I fully understand the want for using fasteners as used on the original.
    On just small engines that really aren't models, but miniature engines (think Elmer Verburg or Rudy Kouhoupt) I have a different take.
    In this case I don't understand the hatred of socket heads. Personally I think they look better than pan head screws (with screwdriver slots/crosses). Much industrial machinery today is assembled with socket heads because with one small wrench set, you can turn many different sizes of screws.
    I've built some PMR engines and changed out the supplied binder heads with socket heads. Slotted screwdrivers to drive scaled 1" screws don't exist. Hex wrenches to drive 1" screws do exist and in scale I think it looks better.
    So I ask, in the case of a non-model, why the continuing hatred of socket heads?
    ...Ved.
  5. Oct 19, 2014 #5
    Swifty
    Swifty
    Swifty
    Mar 6, 2012
    2,253
    816
    Vederstein, I'm another one that hates pan head screws, they just don't look right on an engine. Certainly for models of older engines they look far better with hex bolts or studs and nuts, but for newer designed model, give me socket head screws anytime.
    Chucks idea for making hex heads is great, but do you fill in the socket afterwards? Even a bit of JB weld would be OK to fill it in with.
    Paul.
  6. Oct 20, 2014 #6
    cfellows
    cfellows
    cfellows
    Aug 26, 2007
    3,891
    697
    I think the aversion to socket head cap screws is mostly for model engines that are scale relicas or perhaps period specific where SHCS's would not have been used on the full sized original. It all depends on the look you are going after.
    Certainly filling the sockets with JB weld or some other filler would add the look of realism. I usually just leave the socket open so I can continue to use allen wrenches with them.
    Chuck
Share This Page
