Shop Tricks for Disabilities
Tom great mods all round.
Although a wheely not an accident but Neuro muscular problem. I can while using a bench to lean on but only for short periods. Its through this I climb onto a modified draughtmans stool I put 100mm wheels on the ali base and I push the wheelchair out of the small workshop and then I can wiggle/move around all my machines. Mostly woodworking and as the stool is a gas lift I have to set the height first then climb onto it.
My kids stir me for being short, so I think I'd need a step ladder to climb on that chair Ray, and I'm pretty sure I'd also immediately fall off!
Hmmm, motorised chair, there's a thought! On a more serious note, the fortitude of some you guys really do make me feel bad when I whinge about trivial things, quite amazing and admirable how you just don't let things hold you back.
cheers mate, Ian
Hi Tom
I am just starting with my home machine shop.
I am inspired by how organised, clean and versatile your adaptation seem to make it. I have been working with people with disabillities and modifications and adaptations to equipment in vanuatu.
Thanks for the inspiration
Frank
On the lathe a wall mount for a TV supports an old Bridgeport tool holder, the box on the wall is all lathe tools
Then swings out of the way
This lift is bolted to the back of the lathe, used to swing the chucks and work pieces for the lathe
Yeah the BB pillowblocks were overkill, but it sure spins nice
Heres a chuck with the lift bracket, the block and tackle is quick it needs to lift about 40 lbs is all
To lift heavy stuff there is a 4K cherry picker, this is an invalid lift 300lbs at the hook, overhung +18" safe at 50lbs, battery powered
Thanks for looking, I hope someone can use these idea's for themselves.
Tom
Wow this Shop is Great ! I'm in a wheel chair for 25 years now and have got back into machining the last 6 years hence i had my own business and bought a rebuilt a South Bend 10 & 9 inch lathes a shaper and a small Clausing mill with a Bridgeport M-head mounted on it all work great, I build steam and gas engines etc Keep Up Th Great Work
Thank You
Alec Ryals
Yeah, fifteen years last august for me. It seems this last year my age has caught up to my condition. But I will keep fighting until I lose, whenever that is.
Thanks for the kind comments regarding the shop. It much messier than the photos show, more equipment as well.
Tom
I have added more wonderful tools to burden my kids with when I am gone. As well as use while still here.
zxWbMoVTPQImC_cLAD0JyX4BBNdk2SjG50JZLVJoCMdBeW4CozKgc1WSjWV4SUSp0-0Ddp_IfP9hwgIRO9mdj_mhkrgCB3oOUd8-KiuExHy-EACyFfOAk6ta2-etEF-bl2wJGdWttA=w946-h452-no
View of the shop
AF1QipMb0nSGzlqFf-3bvPbYKoDgtSu3YO5Ih9uJZ4nL
td51E1mkNYh84Ezn1vQaiiWmfjron99_DtScxfHV7PppjtCqH3J-n5zwk8Xzwxo1iRRVB0uskDNEtJfbeVvvaAn9Tw7l4s8YYjnTpcO1_9hMhkY_CIBRNg_glYHe5eeK7Bkot9_8AQ=w946-h452-no
The shelves used to be stocked with a decade worth of business records, all gone now. There are 4 roll out shelves currently, with enough slides for half dozen more.
AF1QipMS1eLSnBJw4m7YOBJdGSkqAjRkcW926rQMEDoF
zc1afLAEuyA3WcV76oiyxwQg1y5xujny3I1Qe9RK8gOZ9nYJaMobbX5BeNTg7TkYRU_Uqx-KUdwFVAscizgcrDJzuzxCfNikHLnqDHUQQGCl6GwoID6xT1-DXAYsPBQm0dTPry1scg=w268-h474-no
The lift for the lathe lines up with the shelve for the chucks. The wood tool box was made by my Dad 60 years, I was 6 at the time, special.
XNCP5KVw4RwX1iyRBn3QX0__BU-p5akbyGYbJXGkw92fqORRzzCaLa8YQW-yjxvDYwkhPMK0cmjCILEjUHKzfc5dZIvkmnrbiTLSHQ3V4Yq7GeP_ONAgSwseRPPEvYkIrn3jT-NjoA=w843-h474-no
-ck0oShGjvWmAOSsglHK9bule5HE8BnV26CmfFtesc1_Db-aP49q4B09iUHb55UkmbZRiwOeHhDgty7RPq4X05HETBPpgl7zJqt3vZxGkSDrFQFWSGf4NgvPnnwJxr3-gPDaNqMtGQ=w946-h452-no
AF1QipMqZbzPsi3F4pd2c9OZE2xnUbrIQSfX54Zc4m9I
Perfect. Don't change a thing. My shop is similar and I would feel comfortable in your shop. Best of all, it's a Grandpa's shop where we can share skills, safety and creativity with our grandchildren. It's where they can develop the confidence to 'fix' anything. Congrats and thanks for sharing.
That is a Monarch 10EE. That originally had a Tube drive, BIG vacuum tubes made DC current to drive monster 5hp motor. I replaced with a 5hp motor VFD drive.
The lathe will swing 12", but rated as a 10", rather stout 3200lbs.
Love It.
First photo shows the Surface Grinder, as well as a Myford Cylindrical grinder.
Because I have a fusion at C3C4 in the neck, I have limited movement in my neck. I was using mirrors often to see things. Now a cell phone is quite useful to look at the compound slide radial graduations or looking in a bore or looking at the dial indicator on a mill when used in mirror mode.
Another tool that is useful is a bore scope . It has a camera on a stick and is useful as I can no longer move my head around to look at things like I used to.
One thing I find useful, when using my battery operated drill. In order to keep the hole perpendicular, I have fitted a small spirit level to the top of the drill. As I'm drilling the hole, I look down from above, which gives me correct left/right angle and the spirit level tells me the correct up/down angle.
Jack
