Hello all.
A good few years ago, I did away ( almost ) completely with my oil and whet stones for all of my wood working tools and moved to the Scary Sharp method.
This basically involves sharpening on Ali Oxide paper tacked to sheets of glass instead of using stones. Just like most people that have written about it, I find it much quicker, much easier, provides a much better finish and is generally easier to do. It's one of those things that once you try it, you don't go back.
See here for a more complete write-up:
http://primeshop.com/access/woodwork/scarysharp/
I have been looking at putting together a Worden grinder, and collecting plans for jigs that cover lathe tools, chisels, drills etc. Add it all up, and it's a major investment in time, and I wouldn't expect to get change from £750 minimum as well.
I've just noticed that Warco - as an example - are now selling belt and disc linishers for as little as £50. For that price, I could set up some basic jigs, and essentially use the Scary Sharp method for metal work as well, and I can convert my existing sharpening jigs for the wood tools fairly easily to be fixed mountings.
To go from bare tool steel to a finely honed lathe tool for example might mean 2 machines, which would give me access to 4 different grades of paper, but it would still seem to suggest that it would be a cheaper route to go down.
I was wondering if anyone on the forum had experienced using linishers for sharpening rather than grind stones, and if so, if you had any thoughts or comments you could pass on, either positive or negative?
