- Sep 2, 2011
- 1,335
- 352
not sure if this should be in the "machine modifications" section but here goes.
i am making a tool post for metal spinning on my lathe. the type that has the drop in pins accross a flat piece of steel so you can use your "tool" which is a round shaft with a sort of ball nosed end on it. like a steady would be on a wood lathe for the tools.
my first question is - should the top of this steady rest be centerline with chuck / tailstock? or just a tad lower to compensate for the thickness of the "tool" i will be using?
and if anyone has any recomendations / things i need to be thinking of let me know. ive watched tons of videos and totorials and have seen many failures as well as much success. seems one of the key things is when applying preasure to the stock, you spin it away from the base but just as important you spin it back toward the base and work the metal in both directions.
anyway thanks in advance for any suggestions / help.
