Scratch building the Hicks Oscillator
Cleaning up the cylinder was done mostly with needle files, I do have a Dremel style die grinder but I can inflict serious scarring without any effort so I mainly stick with the files and it gives me time to think of the next steps. The cylinder has two heads, top and bottom but only the top one is on show so I decided to make that in brass for a bit of bling and the bottom in steel. For the piston I turned down a piece of mild steel and gave it a good honing with the electric drill and Gumption cleaning paste. (I must buy some proper grinding paste I said for the hundredth time). The connecting rod was a section of 6 mm ground rod from an abandoned printer, I love picking these up at kerbside cleanups. I lapped the heads and flanges with 600 paper on the surface plate as it doesn't take long and removes the need for gaskets, just a thin smear of flange sealant. A quick blast in the cabinet and all finished. I’m sure there were easier ways to build this and I’m more than happy to listen to any advice. I use the plans mainly as a guide and for critical measurements but make up a lot of things as I go. I really admire other contributors, such as Brian Rupnow who designs in CAD and then builds, mine always seem to be indecipherable scribbles on scraps of paper. I’m often quite surprised when things turn out as well as this has so far, I hope it continues. Cheers, Peter.
Don't knock Gumption too hard.
As far as I know, it breaks down during use, can be flushed out with water and any residue is unlikely to give you grief. I keep swiping a bit from the wife's cleaning cupboard and find it great stuff.
John B
Like daChurchPcGuy, I am new here - only days, literally. And my only experience with metalwork - and machine work in particular - is metal work in school about 45 years ago.
So I want to do more of this kind of work: I come here to admire, to learn, to gain inspiration. It saddens me that people with such skills as deeferdog and others are so disheartened as to not post their experiences.
I can only imaging the amount of effort posting in detail would require, but we are all poorer for their absence - especially the likes of me trying to gain knowledge and hopefully follow in the footsteps of others.
Hey Besty, we were all new here once, I'm only a hacker but I sometimes spend over eight hours a day on my hobby so if I hadn't picked up a few skills by now I'd give it all away. Thanks for your comments, I enjoy writing and now that photography is so easy posting is not as hard as it once was. Most of us are extremely interested in the other persons setup, so if you can find the time, take a few pics of your shed or whatever and tell us what you'd like to build, there's a load of help to be had. Cheers, Peter
Sadly, it would appear that there is not a lot of interest in model steam engine building, as a consequence it would be a waste of my time to continue with this thread so this will be the last post on this subject. Thanks bmac2 for your support. I did finish the engine and I thought it was an interesting build, it taught me a lot. Here are a few pics of the completed engine, it is quite a little runner. Cheers, PeterView attachment 118320View attachment 118321View attachment 118322View attachment 118323View attachment 118324
Great engine.
Thanks for sharing !
What a beauty that is. I just finished a Stuart engine and am looking forward to my next STEAM ENGINE. I spent several years in your country some time ago. Did not know anyone who was interested in model stem engines but wish I had. I think that you will find that there is alot more interest in model stem engines than evident. Stay with us.
Flywheels for model engines can pose problems as far as getting the right material. At op shops and car boot sales I always keep lookout for cast iron weights used by the keep fit members of the population and that is what I had on hand for this engine build. The first step is to turn a mandrel up out of mild steel and press fit it into the boss of the weight. This now allowed me to turn it in the lathe and face it off as well as machining the rim. It’s all a bit of guess and go as sometimes the cast iron can be so hard as to be un-machinable, however this piece turned like butter. The finished size came close to the plans, that’s always a bonus in scratching, and I parted off the mandrel and bored the centre to take a 12mm shaft press fitted.
Over to the mill and the rotary table for the spokes. These aren’t hard, providing you don’t make too many mistakes. If you do, like I did with the miss drilled holes, plug them, machine them off and put them in the right place. Expect to do things wrong unless you make flywheels for a living or have done a lot of them, there are many opportunities to humble the ego.
I fluted the spokes but then machined them off as I wasn't fussed with the look. A bit of work with the file and I was happy. The shaft was a piece of 12mm bright bar and I press fitted this into the hub with a bit of loctite 263 for insurance. This assembly was then returned to the lathe for a final skim across both faces of the flywheel and the rim, if you do this it guarantees that the shaft and wheel will run true without a wobble. (I have built some terrible wobblers in my time until I resorted to this.)
The main shaft pillow blocks for the bearings I had already made, along with the bearings. I certainly didn't bother to make them as drawn in the plans as they seemed far too unnecessarily complex, I just turned them to size and fitted them to the pillow block. Later I will loctite them into the bottom of the blocks.
The whole arrangement turned out OK, it is especially pleasing to see it rotate so true. At this point the engine was really starting to take shape but I knew the greatest challenge lay ahead, and that was the cylinder. If I had realised just how hard this this would be I might not have been in such a good mood, thinking that possibly I was making a bit of progress with this hobby. The thump you hear in the next post is me coming to earth. Cheers, Peter.
View attachment 118458View attachment 118459View attachment 118460View attachment 118461View attachment 118462View attachment 118463View attachment 118464View attachment 118465View attachment 118466
Some years ago I picked a discarded cast iron weight to do what you have done here. Mine was so very hard that I never tried again. You have given me hope for next time.
The valve gear is confusing to anyone reading the plan who has never built an oscillating steam engine, and that was me. I basically just followed the instructions and made the parts as described but didn't really understand the operation until I was nearly finished. Most of the work is in brass making galleries for the steam to pass through. The oscillating interface between the inlet/outlet manifold was lapped using 1200 paper on the granite block as I had been alerted to the fact that most oscillators suffer severe steam leakage at this point.
Most of this section is a bit fiddly and involves a bit of setup on the rotary table for indexing. A few things were changed from the plans but these were only minor and were mainly made to accommodate the material I had on hand. Starting to see the light at the end of the tunnel now, the engine has been very enjoyable up to this point and I would recommend it to any provided you have the equipment, lathe, mill rotary table, good tooling etc. A few pics here and continued in the next post. Cheers, Peter.
That is beautiful! Nicely done. Sorry I missed this thread until now!
Please don't stop posting, have them all saved to file and getting so close to the end, I would not only have the build pictures but the explanations of how and why the parts function, there might be more like me who are and were lookers to get out attention, will only become educated by building on not by looking at the pictures, please continue with the show and tell, Joe
Peter,
What did you use to fasten the manifold pipes into the valve system? Is that silver solder, or some form of epoxy?
Hi John, Most of the joins in the model are silver soldered using 5 or 15 per cent silver stick. If the join looks a bit rough after clean up and will not be painted I sometimes use JB weld as a filler to improve the looks. Cheers, Peter
The Governor
At this point I had completed making all of the parts and was in the process of detailing and general cleaning up, however, as I said at the beginning of this post, the model is part of a bigger project. That project is to have a steam plant, i.e. boiler, water tank, etc, so I decided to add a governor to the model, this is not part of the plans. In my bits and pieces box was a small flyball governor that I had purchased from Bangood in China. These are beautifully made, way beyond anything I could produce and importantly in the right scale for this steam engine. I had to modify it a bit and work out a way to drive it that was in keeping with the engine design. I soft soldered on a pedestal after cutting off the base and mounted it near the manifold. For the shaft I used a 6 mm ground bar from a printer running through two pillow blocks attached to the flywheel supports. In the end it all worked OK but it was a bugger of a job to align. The slightest misalignment as I tightened things down would cause the governor to bind, eventually it proved to be the longest of all things to get right. I think it was all worth it as it enhances the model quite a bit and I will need it later. Cheers, Peter.
Deerferdog, thanks for the more show and information, I was getting ready to ask about the governor but that is now solved, thanks for the tip on where to get it, again, I appreciate your time.
