IceFyre13th
- Oct 22, 2015
- 56
- 14
GENERAL NOTES:
ENGINE DESIGN BASED UPON ARTICLE IN THE DECEMBER, 1950
ISSUE OF POPULAR SCIENCE (PAGES 196 and 197).
DIMENSIONS:
ARE GIVEN IN mm [INCHES].
SCALE IS 1 TO 1 IF PRINTED ON 11" X 17" PAPER (SEE SHEET 3).
DRILL SIZE #'s GIVEN AS NEEDED, OTHERWISE FRACTIONAL
DRILL SIZES USED.
MATERIALS:
SEE MATERIAL LISTED IN BILL OF MATERIAL.
ASSEMBLY:
SOLDER PARTS TOGETHER WITH SILVER SOLDER WHERE
INDICATED.
PRESS FIT PARTS SHOULD USE LOCTITE 620 RETAINING
COMPOUND
PISTON TO CYLINDER CLEARANCE SHOULD BE CHECKED FOR A
SHAKELESS BUT FREE RUNNING FIT.
TWO SCREW HOLES ARE INDICATED ON CYLINDER BASE 1,
THESE CAN BE USED TO SECURE BANDS USED TO HOLD
CYLINDER LAGGING WITH #4 SCREWS AND NUTS.
ENGINE INFORMATION:
FINISHED ENGINE WILL RUN FROM 2PSI AND UP TO 15 PSI
STEAM PRESSURE.
Year: 1950
View attachment scraps-solder-engine-assembly.pdf
DIMENSIONS:
DRILL SIZES USED.
MATERIALS:
ASSEMBLY:
INDICATED.
COMPOUND
ENGINE INFORMATION:
STEAM PRESSURE.
Year: 1950
