ConductorX
- Mar 26, 2012
- 132
- 35
I have been reading some interesting books by a guy that built his own lathe and other machine tools. David Gingery is his name.
He says in the book that you can achieve a flat and true surface by scraping the metal. His primary material is aluminum, but he claims it works on steel as well.
Has any one heard of this? Have you done it? Does this method work?
My other question is related to measuring and checking flatness of a piece of metal. How do you determine that a piece of metal is true and flat? I have a lathe bed for my lathe that was in or very near a fire. How do I know if it is true and flat? If it is off a bit how do I fix it?
My last set of questions, I worked many years ago on Ingersoll Rand HHE compressors. We had two 5000 HP and two 2500 HP compressors. The valves in these compressors were reed type valve with spring loaded plates that would open to let the gas in then close with the opposite set opening to let the gas out. We would hone the wear surface of these valves on a huge steel plate using grinding compound. This would insure the valve plates had a true and flat surface to seal against. What is this huge 2' x 2' plate called? It was about 4 inches thick and the top was laid out in squares with a groove between each square where the grinding compound collected.
Is there something like this honing plate that would help me check my lathe bed or help correct small defects?
Thanks for your time as always.
"G"
"G"
