betasniper
New Member
- Apr 24, 2018
- 4
- 0
Hi. Uhm, my background is in machining as I had a mold/tool-maker for a father so I got into that from an early age. I had always taken apart toys to try to see how they work; most of the time failing to put them back together :wall:. I started learning machining at the local community college whilst in high-school and did several model engines as projects for the class; however they never worked as intended. The types of engines are as follows: A Gamma Stirling engine, A compressed air V4 engine, And A 5 cylinder radial wobbler engine. I don't know what exactly went wrong with those projects but fed up with them, I decided to design my own as I was taking a GD&T class at that time. Squared off one is the prototype made with manual machines and a drill press while the other is the proper CNC made one that I made a few months later and both work great, especially considering that was the first attempt at something like that and it has no exhaust vent. Around 2014, I became the Lab Tech for that particular class and this engine --the CNC one-- became the standard project for the Class and now every student that finishes the engine actually has a functional engine to play with instead of a pretty paper weight.
Interestingly, The engine always turns forwards when supplied with compressed air no mater the crank angle the engine was at. Very Mysterious. Any Ideas why?
