That's what it really boils down to isn't it. Since I get about equal accuracy from both my lathe and mill I tend to let the job dictate which machine I use. Some jobs are easier to set up on the mill, some jobs are easier to set up in the lathe, although for the past several years it seems the balance of boring jobs has tipped in the direction of the mill. Also, quite a few years ago I spent the money to buy a good US-made boring head and when I dial up .0005", it will give me .0005"!steamer said:If it gets the hole in the right place to the right size....it's the right way for you. - Dave
Boring bars are used for either mill or lathe.When using a boring head and bar, is it better to use the mill or the lathe??
Get yourself a feed and speed chart and post near your machines.And should I be using a fast speed or slow?
