pressure gauges
Discussion in 'Boilers' started by Anatol, Oct 7, 2018.
  1. Oct 7, 2018 #1
    Anatol
    Anatol
    Anatol
    Jan 22, 2018
    265
    39
    Gender:
    Male
    Los Angeles
    What kind off pressure gauges should (and should not) be used for steam?
    I'm guessing all stainless or non-ferrous internals.
    Dry or liquid filled? (I see the recommended operating temp range for glycerin filled gauges is 40-140F.)
    thanks!
  2. Oct 8, 2018 #2
    Charles Lamont
    Charles Lamont
    Charles Lamont
    Mar 24, 2011
    571
    151
    The gauge should always be connected with a condensing U-bend or coil so that it does not see steam.
    Anatol likes this.
  3. Nov 5, 2018 #3
    John Antliff
    John Antliff
    John Antliff
    Active Member
    Aug 7, 2018
    35
    18
    Gender:
    Male
    New Zealand
    Most if not all pressure gauges are made from non-ferrous materials. The bourdon tube, that's the bit that tries to straighten out as the pressure inside it rises and thus moves the pointer, is usually made from thin hard copper sheet and is soft soldered. That's why it should never see steam because steam under pressure may have enough temperature to melt the solder! Steam at 100 psi is 163 C - hot enough to melt most soft solders!
Share This Page
