Sshire
- Jun 29, 2011
- 936
- 259
It seems as if, when I near the end of a build, I begin thinking about "what's next." I have 4 sets of plans on the bench, but, I would really like a power crossfeed for my lathe (Grizzly G0602 10x22.)
After I made the power carriage feed (independent of the spindle speed) I realized the improvement in surface finish was significant over hand cranking.
I have many questions and some parameters for you guys to follow.
1. There is no room at the rear of the carriage or underneath.
2. This is NOT the first step in CNCing my lathe.
3. I want to be able to use the power crossfeed OR the handwheel without going through some major changeover procedure.
The two possibilities that have occurred to me are.
A. A cogged belt drive with one pulley on the handwheel collar and the other on the motor shaft. The same type of windshield wiper motor that I used for the carriage feed with an H-bridge controller and variable pot.
B. a stepper motor between the crossfeed screw and the handwheel. This would be similar to the CNC conversion but minus the ball screw stuff, etc. Some type of controller to control speed and direction. I know less than nothing about steppers, controllers, etc. but I'm a quick learner. I realize that this will move the handwheel out, but it's not an issue.
Your thoughts are encouraged (actually, I'm begging for advice here)
