posting my builds....finally
terry123
Active Member
oklahoma USA
Ive been a member for some time but not very active- work / life / more work ect.
Having recently retired, one of my goals is to participate more; sharing, learning, and enjoying the hobby.
Attached photos (hopefully) show my first 2 builds from a couple years ago. The one on the left is Philip Duclos' flame licker. Like alot of folks here have said it took as much time to get it running as it did to build!
One on the right is a Jan Ridders Sterling. Surprisingly enough it ran on the first go around!
I have since completed a PM Research mill engine and vertical boiler, And a Stuart Beam engine.
Currently working on Myfordboy's Traction engine.
Will begin posting more photos once I determine if I have the posting process understood.
the screws in the flywheel on the flame licker - did you do a multi piece flywheel or fill it with lead or something? both are good looking engines and would really like to see the traction engine progress. i bought the castings and started on it but soon realized i needed more practice before butchering up the castings.
Multi piece as I did not have the correct thickness.
Oddly enough I had been following your progress on the traction engine as motivation to keep me plodding along with mine. I will post some progress photos soon. Although photos of the boiler will be limited due to horrid soldering job:eek: . The only positive note on the boiler is that it had a successful hydro!
Nice looking work!
I like horrid soldering jobs. Reduces my anxiety a little. Maybe someone will post comments what you did wrong, so that we can learn a little armchair soldering. :)
I am quite proficient with welding. My cooling cracks, blow holes and slag inclusions are quite good.
Having many, many years as a pipe welder I figured soldering would be a piece of cake.....not so! I recently purchased a Sievert torch and plan to use it on the horizontal boiler for my Stuart beam engine after the traction engine is finished. Im thinking it will get better heat soak than the smaller torch I previously used.
My only advice is to practice on some smaller parts first, that way you get to understand houw the cleaning action, heating spread, etc. works together.
i have an old tank of mapp gass wtih a good size torch that has helped me alot with silver brazing. oxy accetaline would get to hot to fast and i would ruin a part, propane just not hot enough fast enough. mapp gas seems to hit the just right zone for me. only problem is that tank is now empty, hopefully the local air-gas store will refill it. i know you can get the little plumbers torch size of mapp gas but just dont think that will do for me.
the tank and torch were given to me and that tank was almost full when he gave it to me.
Just now noticed your avatar photo....That is absolutely stunning! I tried the "engine turning" effect on my base but just wasnt consistent enough on the finish. Did you use an abrasive?
i used scotch brite pad on the end of a 3/8 wood dowel if i remember the size corectly. what i did was turned a punch that would cut out a 3/8 piece of scotch brite and then hot glued that to the tip of the dowel. i used wd/40 and sprayed the piece of aluminum to lubricate it and used the mill to spin it and then move over / repeat. would have to replace the piece of scotch brite about every row i did. later on Brian Rupnow told me about craftx sticks for doing this. seems to be the way to go if i ever did it again
Werowance,
looking at your in-process photo it appears that the material was polished before you applied the scotchbrite. Did this help achieve the results you got?
i did buff the base to near mirror finish before doing it. it helps alot in my opinion. started with 600, 800, 1000 then 1500 grit sand papers on a surface plate (sheet of glass) then over to the buffer.
i tested on some non buffed scraps i had before i did the real one and it turned out ok but the lines in extruded aluminum plate did still show thru a little. the lines im talking about are the small straight lines alot of flat aluminum bar stock has from manufacturing.
edit: 600, 800, 1000, 1500 is my normal goto before i buff but alot of times i dont have 600 or 1500 grits because sometimes those 2 arent availabel at the store. so i often sub 500 grit and 1200 grits and get pretty much the same results after buffing. so if you have trouble getting the 600 and 1500 at the local hardware store i have found they often have 500 and 1200 instead.
