Porsche 917 flat 12 engine
I also had the same problem with Chrome and also with Microsoft Edge, it would be interesting to log in, but there seems to be a problem, a security and invalid certificates
I've ignored those warnings in the past and never had an issue with it, but I'm being a bit more cautious when I keep reading about big name companies being compromised all the time. If everyone else is going there and it's not an issue, it's probably OK. The fact that you're seeing the same warnings with Edge and Chrome (both of which are on this machine but that I rarely use), but Trevor doesn't get the warning is odd.
Cover camshaft, from design to finished cover via SLA resin 3D printer
I split the cover into 2 parts to use my printer (200x140x200 mm )
Phase of curing with infrared rays to polymerize and harden the pieces after printing
matt black paint
logo painting with rubber roller
looking realy nice. is the ventilator scale? it looks a little big in relation to the block.
Michael
Jules,
how long do ou estimate for completing the build?
I realy like to hear and see it running.
Michael
by the way now that the summer is gone i will go on working on the Holt.
Jules,
Michael
Hopefully, I hope to hear the first pops within the year.
After first pops I would like to try to build a mechanical injection system but the insuperable problem is the diameter of the injector holes which, according to my calculations for a piston of 26 mm it must be max 0.06 mm.
:oops:
Distributors
This engine has 2 distributors, each for all 12 cylinders, there are 2 spark plugs per cylinder
I built 2 distributors, one for 6 cylinders on the right, the other for 6 cylinders on the left, in my heads there is no space for 2 spark plugs 1 / 4-32 each cylinder , I also made cost savings.
Instead of making 2 tabs and 2 screws to hold the distributor cap in place I put an Oring, this allows the timing by rotating the cap
The magnets and the Hall sensor will be positioned directly on the crankshaft , any backlash on the gears does not affect the timing.
The central electrode is obtained from an electric motor brush by turning
