Plans for Carburetor?
Discussion in 'Plans' started by neil_1821, Nov 2, 2016.
Help Support HMEM by donating using the link above.
  1. Nov 2, 2016 #1
    neil_1821
    neil_1821
    neil_1821
    Active Member
    Mar 5, 2015
    44
    12
    I've been doing a lot of googling and searching on this forum and I'm still struggling to find a source for plans.
    I'm looking for carburettor plans specifically for the hoglet V twin engine. I understand you can use a model engine one but it just doesn't seem to fit the overall look of it. I have seen some with nice carburettors but I can't get any further.
    Can anyone point me in the right direction?
  2. Nov 2, 2016 #2
    stevehuckss396
    stevehuckss396
    stevehuckss396
    Senior Member
    Nov 19, 2008
    3,788
    885
    Try jerry Howell's web site. His son sells all his dad's drawings and the two jet carb is also available. A little bit of work in Google and you should be able to find your way there.
  3. Nov 2, 2016 #3
    Blogwitch
    Blogwitch
    Blogwitch
    Ex Bogstandard
    Dec 26, 2008
    3,636
    619
  4. Nov 2, 2016 #4
    neil_1821
    neil_1821
    neil_1821
    Active Member
    Mar 5, 2015
    44
    12
    Excellent, thanks chaps.
  5. Nov 2, 2016 #5
    lantain1982
    lantain1982
    lantain1982
    Sep 19, 2010
    21
    5
    Recently completed my Hoglet. Used Jerry Howells twin jet carby.
    Down loaded the plans. As noted good clear drawings and notations.
    Two options given. I used the fuel inlet at 45 degree option but in hind sight I should have used the alternative which is more suitable for the Hoglet application.
    Once I mastered the needle valve settings the carby responds very well over the full
    throttle range.
  6. Nov 3, 2016 #6
    Gordon
    Gordon
    Gordon
    Jan 4, 2011
    391
    57
  7. Nov 3, 2016 #7
    Brian Rupnow
    Brian Rupnow
    Brian Rupnow
    Well-Known Member Project of the Month Winner
    May 23, 2008
    10,358
    3,128
    Gordon--that isn't my version of the George Britnell carburetor. That is my version of the Malcolm Stride carburetor as originally used on the Jaguar and Bobcat engines.--Brian Rupnow
  8. Nov 3, 2016 #8
    Gordon
    Gordon
    Gordon
    Jan 4, 2011
    391
    57
    Brian: You are correct. I used your Rupnow/Britnell design which I had picked up where you posted it on another forum. Not sure now which forum. I modified your drawings and one I received from George to fit my needs and tooling. I had not paid enough attention to your vertical drawings and just thought that they were the same. Thank you to both you and George for your work on carburetors. They give a good starting point for building a carburetor.
Share This Page
