I am busy preparing to build a 4 stroke single cylinder Webster. I do however have a few questions on the material to use for different components.
The plan says:
1.Use 12L14 steel OR cast iron for the sleeve.
2.Use 6061-T6 Aluminium forthe piston and conrod.
3.The material specifiedfor the crankshaft is CRS (I am not familiar with this abreviation)
4.Valves are to be made from steel OR stainless steel.
I have available:
1.Cast Iron HT250
2.High Carbon Steel BS970 655M13(EN36B)(Case hardening)
My questions are:
1.What is the theory behind the different sleeve/piston/rings material combinations? What go with what and why are there different combinations (I have seen different options in different literature) Perhaps somebody has a link to a site to explain this in detail?
2.Will the HT250 cast ironbe OK for the sleeve? I would prefer cast iron for the sleeve for the ease of machining the fins. (If there are no obvious disadvantages above steel)
3.If you recommend castiron for the rings, will the HT250 do? I would like to try my hand on the manufacturing of rings, as I have a very good tutorial on it.
4.I plan to cast the aluminium stock from old truck pistons, will that be OK for the piston?
5.Will the EN36B be OK forthe valves and sleeve and should I go the steel sleeve route?
6.Why aluminium for the conrod? I am worried about stress singularties on
the conrod, as the tinyradii is difficult to be exacton (for me)
I realise that some ofthese questions might be irrelevant to a basic engine like the Webster, but todig deep into the basics makes it just so much more interesting to me.
Any help and/or pointers will be highly appreciated.
Kind regards
Johann
The plan says:
I have available:
1.Cast Iron HT250
My questions are:
Kind regards
Johann
