Parting Off (Again)
Help Support HMEM:
Ken I
Cape Town, South Africa
This may be an old trick but its new to me.
My hobby lathe does not have coolant and trying to dribble in HP cutting oil whilst parting off it tends to throw it out before it does anything useful.
How to deliver coolant to the cutting edge ? Then it dawned on me to use a syringe :-
Delivered where its most needed and allowed me to go all the way in without any binding.
Parted off - warts and all.
I advanced the cross slide with my left hand while delivering (Rocol) cutting fluid with my right. I am a southpaw - maybe that helps.
The needle is cut off and blunted so I don't hurt myself with it.
The whole cut only used about 1.5cc of oil so its less messy as well.
This is the first time I ever tried this and I was so pleased with the result, I thought I'd share the tip.
Regards, Ken
Lloyd-ss
HMEM Supporter
Charlottesville, VA
I have that same HSS parting tool and would never think about plunging it that deep. With your idea, maybe I will now.
Thx, Lloyd
Ken I
Lloyd, that's a 3/32" PO blade into 30mm dia. chewing gum grade extruded aluminium bar - just for scale. 4mm drilled hole on centre.
I did have to back just a bit up once rather sharpish due to me not keeping the lube flowing (trying to take photos at the same time) - you can hear it developing in time to react to it - my fault.
The second part off went flawlessly with no working it sideways whatsoever - just the one plunge cut.
This horrible gummy grade of aluminium would normally be a sod to part off.
Regards, Ken
Thommo
Active Member
Collie Western Australia
You might want to try kerosene on aluminium. That’s what I was taught to use and it gives ally cuts a great finish
Regards, Ken
L98fiero
Keswick, Ontario
Regards, Ken
I just use a half inch chip brush with tapping fluid or a dark cutting oil, a little messier but uses little oil and it's quick.
Thommo
Active Member
I placed this post earlier but it seems to have mixed in with Ken I’s post. I was always taught that kerosine is the best cutting fluid for aluminium. You don’t need a lot of it, but it always results in a beautiful finish, but that is assuming that you have a sharp cutting tool and the correct spindle speed and cutting rate.
