- Jan 17, 2009
- 1,081
- 278
Hy guys, there are several threads on the Edwards 5 some quite old.
I opened this thread to discuss any issue without hijacking any other thread dedicated to a single topic.
If you have a question, a problem, a suggestion or anything related to the subject you are welcome on this thread.
I start with one:
I believe have the latest drawing of the Oil Pump
Sheet 26 Rev A02
Sheet 27 Rev A00
Sheet 28 Rev A01
I suppose that the RH side of the pump as drawn is the suction part and the LH side is the output side.
I cannot figure how the pumping action works relating to the operation of the check valves.
How can a 0.125 ball in a 0.125 hole act as check valve
On the suction side the ball runs into a 0,136 hole, but I fail to recognize the seating seal.
Are the brass tubes on the right between body and cover part of the ball seat, requiring to have a
smooth & square lip?
Has anybody run the pump and observe oil moving through?
I start with one:
Sheet 26 Rev A02
Sheet 27 Rev A00
Sheet 28 Rev A01
