nuts
Discussion in 'Tips and Tricks' started by firebird, Nov 27, 2010.
  1. Nov 27, 2010 #1
    firebird
    firebird
    firebird
    Oct 26, 2007
    1,133
    6
    Hi
    I like to use stainless steel on my engines for piston rods and linkages etc. I have accumulated a decent stock of imperial sizes, my lathe and collets are imperial. However sourcing brass nuts to suit has caused me a few problems so I have looked into it in some depth to find a practical solution. I was using 7BA brass nuts for 3/32 rod but they are now apparently no longer made. The following is what I have been using for some time now and are readily available. Although there are slight differences in diameters in practice they work well.
    For 1/16 rod I use 10BA. 10BA = .066 1/16 = .0625 a difference of .0035
    For 3/32 rod I use 2.5mm. 2.5mm = .0984. 3/32 = .0937 a difference of .0047
    For 1/8 rod I use 5BA. 5BA = .126. 1/8 = .125 a difference of .001
    For 5/32 I use 3BA. 3BA = .1614. 5/32 = .1562 a difference of .0052
    I have sourced some steel 1/8 nuts (1/8 x 40) but I can't get them in brass.
    As mentioned above there are slight differences in the sizes but in practice they all work well.
    I hope this is of some use.
    Rich
  2. Nov 27, 2010 #2
    Twmaster
    Twmaster
    Twmaster
    Oct 24, 2009
    917
    3
    You could get brass hex rod. Center drill and tap to size. Part off.
  3. Nov 27, 2010 #3
    doc1955
    doc1955
    doc1955
    Gone
    Aug 27, 2009
    1,118
    76
    Occupation:
    Retired Former Tool Design Engineer
    You can get brass nuts here I've ordered from them and I'm happy with their fasteners.
    Micro Fasteners
  4. Nov 27, 2010 #4
    firebird
    firebird
    firebird
    Oct 26, 2007
    1,133
    6
    Hi Mike,
    I did try that but its a bit of a tedious job. It's surprising how many nuts you use on a job. Plus it would mean buying brass hex in all the different sizes and there was a fair bit of waste.
    Doc, I tried most of the UK suppliers. None I could find make brass nuts to suit the small sizes I was using, 1/16 3/32 etc.
    cheers
    Rich
  5. Nov 27, 2010 #5
    doc1955
    doc1955
    doc1955
    Gone
    Aug 27, 2009
    1,118
    76
    Occupation:
    Micro Fasteners will ship to the UK won't they? Not sure what the shipping cost would be.
  6. Nov 28, 2010 #6
    johnthefish
    johnthefish
    johnthefish
    Jan 11, 2010
    8
    0
    Its not so much the shipping costs but the v.a.t. at 17.5% (soon to be 20%) we have to pay. Plus the Post Office our end have the cheek to charge us £7 to collect the tax. :eek:. When the exchange rate was $2 to the £1 it was worth it,but not now. :mad:
  7. Nov 28, 2010 #7
    Jasonb
    Jasonb
    Jasonb
    Project of the Month Winner!!! Project of the Month Winner
    Mar 30, 2008
    2,392
    419
    Surrey, UK
    EKP do 3,5 & 10 BA full nuts in brass. I think they cannot get 7ba hex any more so thats why they no longer make them.
    http://www.ekpsupplies.co.uk/index.php?act=viewCat&catId=55
    The small fractional nuts are not made as model engineers have been using the same BA threads on 3/32 and 1/16 rods for years so there is no real demand.
    Doc even if micro fasteners do ship to the UK it would be no different as the small UNC and UNF threads are not exact matches to the fractional rod sizes.
    Firebird even if you could source fractional threaded nuts you would have a hell of a job finding suitable taps & dies, I think 1/16x 60 will do the 1/16 rod but there is not much about at 3/32nds
    Jason
  8. Nov 28, 2010 #8
    Noitoen
    Noitoen
    Noitoen
    Dec 26, 2008
    623
    11
    Looks like, your next project will be a dedicated CNC to manufacture small nuts ;) ;) :big: :big:
  9. Nov 28, 2010 #9
    firebird
    firebird
    firebird
    Oct 26, 2007
    1,133
    6
    Hi
    Thank you all for your input.
    If you look at my beam engine project you will get an idea of the number of nuts required. I think there are 22 3/32 studs in the cylinder alone which have 7BA nuts (no longer available) hence the reason I looked into alternatives. By keeping an eye on e bay I have been able to pick up the sizes listed above quite cheaply. I have just bought 100 3BA brass nuts for £4.00 including postage.
    Rich
  10. Nov 28, 2010 #10
  11. Nov 28, 2010 #11
    Blogwitch
    Blogwitch
    Blogwitch
    Ex Bogstandard HMEM Supporter
    Dec 26, 2008
    3,697
    667
    Gender:
    Male
    Occupation:
    Retired Aeronautical Engineer
    Crewe, Cheshire, UK
    Hi Rich,
    These people have a good range of cheap fasteners, but some of their packages contain rather large quantities.
    http://www.fastfixdirect.co.uk/
    I notice you have also strayed into the ME range of threads, they should be available from ME sources who also sell your BA stuff.
    I make my own nuts normally, and now I have exhausted almost all my old stocks of BA brass hex bar, I cut my own bar up whenever I need some. A real PITA, but at times, needs must.
    That is what ME is all about, making do with what you have around you.
  12. Nov 28, 2010 #12
    max corrigan
    max corrigan
    max corrigan
    Aug 24, 2008
    156
    4
    Rich i just googled 7ba brass nuts and it seems that "modeller's Mate" do 7ba brass nuts in various quantities per pack, ie 25@ £3.32 maybe worth a try!
    Regards Max.....
  13. Nov 28, 2010 #13
    firebird
    firebird
    firebird
    Oct 26, 2007
    1,133
    6
    Hi
    Thanks John I'll check them out.
    Max, I tried ordering from most of the model engineering suppliers who have them listed but they all replied sorry out of stock!
    Now that I have sorted out what I can get away I'm pretty well stocked up again. I just thought I'd pass on the info.
    Rich
  14. Nov 28, 2010 #14
    Bluechip
    Bluechip
    Bluechip
    Jun 21, 2008
    226
    0
  15. Nov 28, 2010 #15
    firebird
    firebird
    firebird
    Oct 26, 2007
    1,133
    6
    Hi BC
    That's one company I didn't try. I suppose there will still be some who still have some old stock but I was told by several suppliers that 7BA are no longer made. Just to re-cap I needed brass nuts to fit the sizes 1/16 3/32 1/8 5/32. As far as I can see nobody supplies brass nuts in ME threads to suit those sizes so the list above is what I came up with. Not perfect but works well enough. Stainless steel in those sizes is readily available at a reasonable price and the brass nuts I have listed are also readily available.
    Rich
  16. Nov 28, 2010 #16
    Bluechip
    Bluechip
    Bluechip
    Jun 21, 2008
    226
    0
    Rich
    Probably the best way to go. Most commercial nuts, BA, Metric or W.H.Y. are hideous anyway ... :eek:
  17. Nov 28, 2010 #17
    Jasonb
    Jasonb
    Jasonb
    Mar 30, 2008
    2,392
    419
    Surrey, UK
    ME sizes start at 1/8" see my first post about the lack of 1/16" and 3/32" thread sizes let alone nuts. Whitworth would be teh only likely candidate but they are hard to find in large sizes, small would be even harder
    EKP that I linked to make 90% of the screws sold by UK Model engineering suppliers so if they can no longer get the hex none of the companies they supply will be getting new stock
    I find EKPs nuts and hex screws perfectly acceptable, they are fully turned not pressed like a lot of the cheap mass produced metric ones. They have a chamfer on one side only and are taller than the mass produced items
    Jason
  18. Nov 28, 2010 #18
    firebird
    firebird
    firebird
    Oct 26, 2007
    1,133
    6
    Hi Jason
    Yes sorry I know ME threads start at 1/8 the sizes listed are the sizes I use, I didn't make that clear.
    Rich
  19. Dec 21, 2010 #19
    MachineTom
    MachineTom
    MachineTom
    Senior Member HMEM Supporter
    Oct 20, 2010
    896
    124
    Look at US machine screw sizes, a 0- zero size is .060, each size after is + .013, so a #2 is .060 +2*.013 or .086, a #4 is .060 +4*.013 or.112". A #3 x48 NC or 56NF would be .099" major dia, right for your 3/32 rod.
Share This Page
