Gordon
- Jan 4, 2011
- 824
- 126
My mill has a NMTA 40 taper. Recently I had reason to use a CAT 40 holder. The basic taper is the same and they both have 5/8-11 threads but the NTMA is about 3/4" longer and the CAT has a pull stud. I solved the problem by making a longer draw bar but I do not understand how the pull stud works. Is there a way that I can make a draw bar which would work on both? At this point I can put a 3/4" long spacer on the draw bar but that involves removing the draw bar and threading it through the hole in the low ceiling. Do not move the mill unless you want to drill another hole in the ceiling. How does the pull stud work? I can find pictures and dimensions of them but I do not know how they work.
Used CAT 40 tooling is much easier to find than NTMA 40 tooling.
Gordon
Gordon
