Well the mill is in place.
When my buddy and I took it out of the crate we moved what we could down to the basement. The 2 remaining pieces, the base and the column would need an appliance truck to get them down the stairs.
Saturday my sons came over and we started out by moving the aforementioned heavy pieces down to the shop. I had already measured everything and put some tape on the floor as a guide to locating the base. Everything went great. We got the base in place, mounted the column with the bolts lightly snugged until the knee went on. This way I could drop the knee to the bottom to get the column located back to it's original position. The parts drawing showed 2 dowel pins along with the 6 bolts but there were no dowels. The column had 2 tapped holes which corresponded to 2 reamed holes in the base. I used a couple of metric allen screws to get everything close.
The knee was next. I had removed the gib plate to facilitate dismantling so with a coat of way oil it was re-inserted and adjusted.
Next came the saddle followed by the table. The gibs were inserted and adjusted.
Man that thing moves smoothly!
The ram and base were located on top of the column and bolted down.
Now came the awkward piece, the spindle casting with belt housing and wiring. We put some 2x4 pieces of lumber on the table so that we could carry it in and set it on the wood. Once sitting there the knee was cranked up and the head was located onto the ram and bolted. The final big piece was the motor. It was located on the belt housing, the belt was put back on and snugged up.
From start to finish we had about 3 hours of assembly.
The boys were dismissed from their labors and I finished cleaning up the remaining spots of cosmolene, adjusting handles, gibs and what have you.
The next day I ran over to the local home store and picked up the required electrical items. An hour of stripping wires and assembling plugs and it was time for the test. E-stop button turned out, main power on and turn up the variable speed knob. Everything worked just as it was supposed to.
I trammed the head, x axis was dialed in to -0- in 8 inches but the y axis was out -.001 in the rear and +.0017 in the front. (in an 8 inch sweep) I loosened the turret and rotated it back and forth just to make sure there was nothing under it. I reindicated and got the same results. I wish it was closer out of the box but I knew how to fix it. I loosened the turret again, put a piece of wood on the table, cranked the knee up until it just lifted the turret/ram and inserted a couple of pieces of .002 shim on either side of the front fixing bolt. I lowered the knee, tightened the turret bolts and reindicated. I now have -0- in x, -0- in the back and +.0006 in the front. I can live with that.
All that's left to do is mount the vise and make some trial cuts.
I'll keep you notified on the progress.
Here's a couple of pictures. One of the machine and one with it's so far happy owner.
gbritnell
gbritnell said:After 3 years... I really like the reverse for tapping.
If a person has the floor space and ability to move a larger machine I would recommend a machine like a Bridgeport only for the fact that there are so many of them out there (depending where you live) and that a nice one can be had for about the same money as I paid for my machine.
gbritnell
