Nick Hulme
- Oct 6, 2008
- 338
- 84
It was once again time for stripping, cleaning and re-lubing the cross slide thrust bearings and seeing a little galling on the outer I once again I thought it's about time for the roller thrust bearing modification.
A quick trip to the bearing shop with a pocket full of Myford parts yielded suitable bearings.
5 minutes in CAD/CAM and 10 minutes on the milling machine and the cross slide end plate had exactly the right depth recess to accommodate the outer bearing.
No machining was required for the inner bearing and everything slipped in place without a hitch, reassembled it looks as if nothings changed, until you wind that super silky smooth handle
- Nick
- Nick
