Hello together,
In line with building my 3 cylinder rotary engine, i decided, that i need a cnc milling machine...to much similar parts to do them manualy (At least for me).
First plan was to build a complete milling machine from scratch:
http://www.homemodelenginemachinist.com/index.php?topic=6285.0
But..a friend of mine offered me the column and crossslides of an old Deckel G2 engraving machine.
In the car:
http://gtwr.de/DSC00012.jpg
http://gtwr.de/DSC00013.jpg
Moving it down into the basement:
http://gtwr.de/DSC00014.jpg
Assembled:
I was suprised, how sturdy that machine was built, in fact it was only an engraving machine..
After a bit of cleaning and painting:
Now i needed to convert all screw drives to ball screws and mount steppers..and of course, build a vertical head:
I used the spindle housing of an X2 mill and a ER32 collet chuck with a straight shank of 25mm diametre, the bearings angular contact bearings.
Runout is nearly zero...
The steppers:
4A, 3Nm of torque, more than enough
The Z-Axis Drive, ballscrew, stepper and mounting bracket:
X, Y and Z Axis Drive:
First test, using mach3:
http://gtwr.de/DSC00103.jpg
Drawing circles and lines
As the spindle is not finished yet, i temporary mounted a Router to the machine, to do some ligh milling..:
Here i cut a hole for a SubD 25 connector in a case:
And finaly i got a short video of testing the x axis:
[ame]http://www.youtube.com/watch?v=uwEEaB2MjUc[/ame]
Speed aprox 2500mm/min (~100inch/min)
I am happy
greetings,
Stefan
In the car:
Assembled:
The steppers:
I am happy
greetings,
Stefan
