Well, it had to happen now or ........ I'd probably never get round to it : .......... I've been "planning" to do this for the last 5 years at least........ so here we go ;D
My hideaway .......... yesterday
and as of tonight .................. ??? :
So my little space is about to undergo a "slight" transformation ........ it's 9ft wide by 12ft long, however I have to share that space with a Fridge and a Freezer plus lots of other bits .......... just don't ask ... :wall: .... After moving everything, if I open the garage door things fall out on me, so they will have to go back in the workshop ???
Anyway it's part of the original detached single garage, now connected to the house via the utility area, the good news is the downstairs loo (one of the most useful things I ever built) is just outside the workshop entrance door ....... :
Anyway, the Van is stacked with board, timber and insulation so this little bit of space is getting a new insulated floor, insulated ceiling and timber boarded walls ......... "insulated" .......... can you tell I'm fed up of cold weather
After I get the shell sorted I'm planning to build benches and shelving all the way around, electrics and the minor amount of plumbing are all going to be surface mounted so if I decide to stick a screw in somewhere I don't have to worry, if I end up with anything particularly heavy I can cut out a section of timber floor and put in a concrete pad, shelving is going to be generally plywood but hopefully I'll make that adjustable with a few extra router grooves .............. however .........
Useful suggestions at this stage, to add to this tiny "blank canvas" are more than welcome as this opportunity is unlikely to present itself again in my lifetime 8)
Silly suggestions I can come up with myself, humorous ones are most welcome ;D ;D
what the heck, silly ones are more than welcome anyway :
Thank you in anticipation chaps :
