my first running engine
werowance
HMEM Supporting Member
well, I finally have success with an engine. some may remember my failure a while back with a bj cicada that I never could get to run. I decided to back up and try something easier. I decided on elmers #25 wobbler. an I have success.
I learned a few neat tricks along the way, like using locktight to combine duplicate parts ( I made 2 engines) so I could cut and drill both at the same time then heat to separate. I learned that broken drill bits can easily be removed from aluminum using boiling water and alum from your spice cabinet. it disovled the bit without hurting the aluminum - that was pretty awesome.
I left the shaft a bit long so I could add a pulley later and did not angle cut the sides of the cylinder because for some reason I just don't think that looked good. I might cut a radius or round them over but I didn't like the 45deg angle cut like the plans showed so I left it square for now
I have a video, just need to figure out how to post that to. its running on about 15 psi just using a blow nozzel according to my junk regulator
Great little engine. Thanks for sharing.
Very nice ! So rewarding to see your project finally run . Just a little reminder to loose the ring around machinery .Will save you from a lot of pain if it gets caught .
Werowance--Congratulations!! Feels good, doesn't it. That was my first engine also. There is nothing that compares with the thrill of realizing that you have made a real, running engine.---Brian
Built a base for it and ordered a Midwest boiler kit for it. Wanted to make my own boiler from scratch. I understand the type of copper and silver solder and such. But I was not comfortable making a safety valve without first having seen one. So thought it best to do a kit one firstView attachment ImageUploadedByModel Engines1474297184.450669.jpg
Hello looks like a nice quality job. Best regards Tony Wright pufango!
That looks like a quality job. I have made a few engines over the years and I am always so pleased with myself when they run for the first time, like I won a Gold medal or something. A big thank you to my old metalwork master for introducing me to small steam engines.
Thanks for sharing weowance.
