My engines
natalefr
France
Hi everybody
There you are my engines
The first one is Debbie from J. Ridders plans (watch running here)
The second one in progress is a famous Upshur vertical, this project is not simple for me because imperial mesurement is used and gosh ! I must change something and modified....
Natalfr, Debbie is a nice running engine.
My first IC engine was an Upshur Vertical. I learned a lot building it. Yours is looking good so far.
Jack
Connecting rod....
Halfway through the same motor. I use metric and to convert all I did was to use the digital caliper. Set the caliper to Imperial measurement from the plans then press the mm button and you have your conversion.
Hi Rickl I build the pieces in inches I have DRO mm/in In my mill and lathe, but for the axis I use the pieces directly in mm
Do you have photos about your engine ?
Regards Natale
Piston & Co, more adjustement are required for connecting rod
More
Now the rings (cast iron) :eek: is not impossible but is delicate to make...
The rings are bigger than the cylinder of 0.5mm, after must cut with the dremel and ajust (sand with dremel disk)to exactly cylinder diameter photos 059 and 060
Staniless steel flyweel
Distribution gears just a little modified... ;)
More distribution gears :rolleyes:
Cams...
More cams
