My basement shop
stefang
Hi, i want show you my small shop (and the machines there), where i spend way to much time ;D
cheap chinese drill press, small grinder, storage for small components and stock materials, radio, and workbench
more workbench, vise, cheap bandsaw, which i use to cut aluminium stock, under the workbench sits my chinese 4x6 bandsaw, which i got from ebay in a real bad shape, repainted it and redid the electric wiring.
my little 7x12 lathe and a homebuilt small horizontal milling machine
newest addition to my shop, an Aciera F3 milling machine, there is much work left to do..., the shelfes in the back house hand tools, small material like screws, nuts, power tools, and more raw stock.
You see, not to much space there (4x5metres), but i like it :)
Stefan
Thats a neat milling machine, different to what i'm using to seeing in north america. it looks liek the spindle moves in and out on dovetails? Is there an overarm for it as well that fits in the top spindle? You've built a nice little shop, keep at it, lots of floor and wall space to fill up yet ;D
Nice basement set-up. I do like your mill. I could have used one like this for several of the oddball jobs I have done in the past.
Welcome to the board,
Frank
Wow. That is pretty clean for a basement shop. Search for the pictures of mine! :big:
Looks nice and cozy! Good job.
Eric
Thank you, guys :)
how do you manage to keep thing so neat?
i clean up every few weeks, when i cant move anymore, because theres so much stuff on the workbench
yes, the spindle housing moves in and out, its a very common type of machine here in europe, many manufacturers built machines like this (deckel, aciera, schaublin, maho, thiel, sixis, ...)
i think, they are not as sturdy as a normal horizontal mill, but more versatile.
And yes, there can a overarm be fitted to the head, or a vertical spindle head (which i dont own :(, or even a punching head.
Thank you :)
You should have seen the pictures of that room, 5 years or so ago, there wasnt even a concrete floor, just the plain ground...
I like the benches you built for your machines, seems like a good use of the availible space.
Stefan
Beautiful ,high quality mill..The red paint detracts from the appearance just a bit..Why is the mill on riser blocks ? It was too short for you or you did it that way to enable easy access for a forklift or pallet jack? ..I set several of my machines up on riser/platform of one kind or another , this the only time I seen anybody else do it.
Great looking shop there!, a friend of mine has a similar mill to yours, that has the vertical head attachment, I don't remember the make but it's a bit smaller than yours, he said I was welcome to take it away! as he has 3 other big mills and he doesn't use it but I have to drive from Italy with a van to get it!, one of these days......
Giles
Yeah, but its not the original paint. Some day in the future i will repaint it...without the red on the table :D
There purpose is to get access with a pallet jack, but they will be displaced by real machine feet soon.
Go for it ;D
Stefan
Finally, i moved the milling machine to its final location and added some feets to it :)
Stefan
You're quite the horizontal milling afficionado, Stefan!
I look forward to seeing pictures as you're building projects. I want to learn more about horizontal mills.
Best,
BW
Stefan,
Do you have any more pics or information on your small homebuilt Horizontal mill?
It looks very interesting!
Steve
That looks great Stefan :bow:
As with S_J_H i would really like more detail on your home built mill
All the best
Malcolm
Thank you, guys :)
Yes, Bob, soon i will show some work, that has been done on my big milling machine :)
And here another picture of my homebuilt mini mill:
The machine consists of a welded frame (hot roled steel flat and square tubing), two Bosch Rexroth linear guides and a cheep chinese x-y table, the spindle is powered by a 3phase motor powered by a Siemens VFD.
Some more pictures:
The vertical column, welded hot roled steel with the linear guides attached
The spindle assembly, the big aluminum chunk is the spindlehousing, in front are the two bearings and the spindle itself
Put together..
(All the lathework has been done on my 7x12" lathe :) )
The Motor and the VFD
Stefan
I have an X-Y table just like that. I think I see another project coming my way!
Chuck
Back after a long time...
I finaly got my mill painted:
Also, i have changed the 90° gear drive to a simple 2 stage belt drive directly to the milling machines spindle. The mill now realy is very silent...like a whisper ;D
Stefan
Hi,
today my new Lathe, a 10x22 arived here:
Took it completely apart to get it to the basement, cleaned everything and put it back together (not finished...)
Much stronger and sturdier than my old minilathe (the mini was not a bad machine...but small :( )
greetings,
Stefan, a happy guy :)
