MP5 Glow engine
Help Support HMEM:
ixb1
CZ
Hi Everyone !
This Boy is my new engine project. Finaly finished and documented :)
Parameters are:
Bore 19mm
Stroke 17mm
volume 4,82cc or .29 cu.in
Tested on prop MA 9x4
Fuel FAI 74/26
Plug hot
Video here:
minh-thanh
Viet Nam
Congratulations !
A lot of energy, do you think you're going to make an airplane with it?
lohring
Very nice. What materials did you use for the piston and sleeve?
Lohring Miller
ixb1
CZ
Congratulations !
Frankly in near future not ;)
Lohring Miller
Liner is made from scrap mild steel shaft and piston is out of cast iron "puck".
lohring
Cast iron pistons in steel cylinders were once the most common model engine materials. The engines that come to mind are the Fox 35 and their combat specials. Others were the early OS Max engines. I think it's still a combination that's easiest to lap into a good fit for model engines. Aluminum pistons in chromed sleeves have replaced the combination in performance engines. Ringed aluminum pistons were an intermediate step.
Lohring Miller
ixb1
CZ
This engine is my version of these classic stars.
ixb1
CZ
Make drawings are planned, but there is not enough time.
