Modifying a MT3 Tool Holder
Help Support HMEM:
briankenyn
Active Member
Hi all,
I made the mistake of buying a .375 MT3 milling tool holder with a tang. I use it in my lathe with a Atlas Milling Attachment, and it has jumped out of the taper on two occasions creating quite a mess. I am thinking about anealing the tang with a MAPP torch, cutting it off and drilling and tapping for a drawbar. Will this approach work without destroying the other properties of the taper and holder, or should I pitch it?
Many thanks,
Brian
kcmillin
Brian, When I purchased my lathe used, the previous owner had an MT3 drill chuck arbor with a tang. This severely limited the movement of the tailstock.
I used a bench grinder and SLOWLY ground off the tang and about 3/4" of the solid shaft. If you keep it cooled you can grind it without any issue. (keep a bucket of water nearby to dunk it every few seconds of grinding) I would quench it whenever it started to get warm, NOT HOT.
I would suggest NOT annealing it, you may never get it back to its former self again.
But If all els fails, a short MT3 arbor is very reasonably priced, and wont dent the pocket book too much.
Kel
Blogwitch
Ex Bogstandard
HMEM Supporter
Crewe, Cheshire, UK
Brian,
Just buy yourself a new arbor. Trying to modify the hardened one you have could cost you more grief than the price of a new one.
Bogs
briankenyn
Active Member
Thanks Kel and Bogs,
Enough said, It's off to the store I go.
Brian
