Good day
I am preparing a project based on MODELTEC Crab steam loco. It has a vertical boiler, but the drawings are not finished. I would like to have some opinion from more experienced builders than I am as far as the inside configuration is concerned.
The description is as follows:
The BOILER itself is a vertical fire-tube unit with a water jacketed Firebox. This is a very old and simple design. The Shell and Firebox are made from 8" x 6" Schedule 40 seamless pipe. The Shell is 12" high and the Firebox 4" high. The tube Sheets and Mud Ring are made from 3/8" SA-285 Grade C Steel. The door ring is 2-1/2" Schedule 80 seamless pipe and there are 24 3/4" x .065 wall seamless copper tubes expanded into the sheets. The two through pipes for the Exhaust are made of 1/8" seamless Schedule 40 pipe.
I would possibly like to improve the design, but for the sake of discussion could somebody make a hand sketch showing the disposition of different components (especially the Exhaust 1/8" pipes). I then may do the .dwg drawing and start the possibility of potential modifications.
I may scan the drawing going with the text (only external contour is shown however) and add it to the post.
Thanks in advance
B. Hamerski
Montreal, Canada
Thanks in advance
B. Hamerski
Montreal, Canada
