Lindo
Lindo
- Nov 17, 2013
- 63
- 10
Thought I would keep you posted with photo's of progress so far.
The holding fixture is doing a good job for me in part assembly and marking out.
The height vernier was made from an old digital vernier,cut off the jaws and fitted a new knife edge.
I decided to rough assemble the various pieces for fit check and secure with 10 BA screws and nuts.
Had to use a pair of forceps scrounged from my local vet to hold the nuts
when locating to the screws.
See photo of trimming the wrapper to final height,never enough clamps I find when machining copper and climb milling is preferable to me.
Now a question to the forum,and the experienced boiler builders. Is it feasible during final assembly of the pieces and fluxing for brazing to use 8 BA brass countersunk screws to replace the temporary 10 BA nuts and bolts and no riveting.
As the use rivets in this case according to the book are just a loose fit,I am thinking of drilling and tapping the temporary holes 8 BA, slightly countersink the wrapper for under the screw head,flux, assemble and braze.Afterwards file the heads flush to the boiler profile.
There should be no load to snap the screw heads off during brazing,
but also run a dab of braze around the screw heads for good measure.
This would help avoid some serious hard to get at riveting and the making of special snaps.
It's just a thought.
