Mechanicboy
- Jul 10, 2013
- 955
- 341
Hi Chaffe !
With me : drill - reamer - lapping
Small hole lapping tool : you can buy it or make it yourself - I made it myself
https://www.mcmaster.com/lapping-tools/
Lapping pump cylinders is challenging and very patient
Tolerance : I think it's about 0.01 -> 0.02 mm - I'm not sure - Because it's too small
I used o - ring - just for testing . They fail quickly with high pressure.
The tolerance must be tight to prevent leakage in the fuel pump and still move free. Tolerance is 0.001 mm. Steel piston in cast iron cylinder. First lap the cylinder to final blank as mirror and lap the piston blank as mirror. Then adapt the piston into the cylinder carefully with oil and test the piston is moving free without leakage into the cylinder.
