milling vise plans
dethrow55
texas
hello all just bought a taig mill. and it came with a not so good screw vise . been looking for ideas or plans for a kurt type vise or similar. thanks
XD351
Australia
You might be better off with a small screwless / toolmakers vise . I don't know of any plans for a kurt vise but i wouldn't be surprised if there are some out there on the internet !
DJP
I would purchase the best Kurt style and size for your mill that you can afford. It's the one part of mill that is important for life and a good one is easily justified over a long time period.
In fact, consider buying two. There can be times when securing a long work piece with two mounted vises makes sense.
I built a vise for an Burke horizontal mill with vertical attachment but it never was secure or strong enough. Building it was an exercise in making a vise without having a vice. In the end a 3 inch was the perfect size and I just had to wait for a good deal.
Wizard69
The problem with the Taig and a Kurt style vise is that the Taig is a light weight mill (literally and figuratively). The commonly available Kurt style vises are simply too big for the mill in my opinion. As such I suspect that you would be better off with one or two good screwless vises. (never liked the term "screwless" for this type of vise).
Now all of that being said there is nothing to keep a person or persons from building a small scale Kurt style vise. Unfortunately I have never seen plans for such a vise. Then again I've never looked for such plans. You might want to look towards some of the Asian suppliers to see if you can find a 3 - 4 inch Kurt style vise, again I never looked for such so I don't know if they exist. Still you need to consider the over all size of the vise as it is very easy for a vise to be too big for a mill. Even some of the Kurt vises are too big for a Bridgeport in my opinion.
Your fundamental problem is that the bed on the Taig is only 3.5" wide. As such you would end up with most of the vise and the work piece overhanging the table which is less than ideal. The Taig is actually a good place for a screwless vise that is maybe modified just a bit to bolt directly to the T-slots on the Taig's bed. If I was to design a vise for this mill I would keep that in mind and try to make it as low profile as possible. The idea being to have a vise that is suitable for the capacity of the milling machine.
ruzzie
There are plans for a "light weight vise" in Model Engine Builder Vol 29 - digital back issue is about $6
W 3.75" x H2.25"
XD351
Australia
Fwiw , by the time you buy the materials then machine them ( which may be pushing the machines limitations ) you could buy a Chinese made toolmakers vise twice over ! The vise pictured above is essentially a toolmakers ( aka screwless ) vise and if you get one that has the scallops cut out of each end you can mount it longitudinally on the bed as i did with my X2 sieg . At least that way you will have an accurate , hardened and ground vise and they come in different sizes from 1" up to 4" .
DJP
I agree. The vice needs to be hardened plus parallel and square to the bed to be of any use. Parallels in between the jaws that sit on a precision ground surface are very critical.
Build a vice if you want the experience but best to buy one that is precision ground. The vice that I built was an exercise in using clamps and squares as I didn't have a vise. Since then I have purchased a few that are a proper milling vise and not a drill press vice. Fast and repeatable set up in a milling vise is also important unless you buy multiple toolmakers vises. Some precision milling vises come with a rotating base which is a bonus or they can be mounted without the base if height is an issue.
My thoughts for your consideration. We all need to start somewhere so try making a vise first to build your milling skills and tooling collection. You can always buy one later.
Wizard69
One thing to consider is pre hard steel if you really want to make your own vise. I don't have a Tag so i don't know how well it would handle prehard but it might make for a vise good enough for the home shop. It would save the heat treat steps but not the grinding. It might be possible to get a serviceable vice with fly cutting but you need a precision vice to do precision work.
Honestly expect to end up with a collection of vises as you build up the shop and find good deals. I have three and haven't even gotten a mill yet. You need to be flexible with respect to work holding, sometimes a vise isn't the answer at all.
Ohio, USA
If you want to make a vise to use on a drill press, for practice, to gain skills, make one.
If you want one that is accurate and will hold that little piece securely, I would buy one made.
If you don't have a surface grinder and the skills associate with precision grinding to make all surfaces square and parallel plus heat treating.
You will ether give up on it , or trash it down the road. Don't even consider making a screw push type vise, total waste of materials and your time.
Sorry for what some may find harsh, I have work with too many apprentices from other shops that give projects to their new people and they find out that they have a paper weight, and end up throwing them in the trash.
Just trying to save some people grief.
TP Blazr
New Member
I am looking for simple projects for apprentices to make. No welding, only Cutting, milling, and lathe work, please. Vises, Pens, and the like.
The vise will attach to a workbench. The pens can be made of steel, iron, aluminum, or brass and use standard link refills.
wce4
HMEM Supporting Member
Central Florida USA
Have a look at Projects by Mr Pete. you will find dwg. for several project that others like I have made for free. I will see if I can attach one of his dwg. that I have made to this post.
I hope this helps?
"Mr. Pete (Lyle Peterson aka Tubalcain) has been a huge inspiration to many folks both personally and on the Internet. As an industrial arts teacher, he was responsible for teaching countless students the metal arts and shop work related activities. His heart of a teacher never left him and today he continues to teach anyone interested in the subject matter via YouTube." copy from Projects by Mr Pete.
  • South_Bend_Grinding_Fixture_Hendrickson.pdf
kf2qd
I have had a vise like this for a number of years, and it has worked out very well.
Had to do the usual adjustments. but I use it on my benchtop CNC and it does excellent. It is an angle lock type vise, and made from decent cast iron.
Have a screwless vise and I have come to despise that design.
Joe
Canada
Makeitfrommetal.com has plans for a nice little machinists vise. I made one inspired by these plans, small changes to accommodate the materials I had on hand. Not hardened but ground precisely and taken care of and I'm very happy with the results.
John 🇨🇦
