Mill lighting
Discussion in 'Machine Modifications' started by almega, Aug 26, 2018.
  1. Aug 26, 2018 #1
    almega
    almega
    almega
    Well-Known Member HMEM Supporter
    Mar 8, 2018
    52
    18
    Gender:
    Male
    Occupation:
    Purchasing Professional
    Maumee, OH
    Got this tip from Cogsy. A very BIG thanks to him for the suggestion to pick up LED lights and attach around the spindle. On Amazon I found a make up mirror lighting kit for $10, cut it down to just the lights I needed and stuck them under the head with the included two sided tape. They come with a dimmer, which is a good thing because it is actually too bright at full power - blinding even when reflecting off the nice shiny metal.
    Thanks again, Cogsy.
    LorenOtto, JamesBoeck and Cogsy like this.
  2. Aug 26, 2018 #2
    rlukens
    rlukens
    rlukens
    Well-Known Member Project of the Month Winner HMEM Supporter
    Feb 23, 2010
    136
    53
    Gender:
    Male
    Occupation:
    Retired
    SW Florida
    Great tip. These LED lights are the ticket. Additional benefit besides economy and brightness is shatterproof.
    JamesBoeck likes this.
  3. Aug 26, 2018 #3
    Wizard69
    Wizard69
    Wizard69
    Mar 9, 2013
    1,330
    264
    LED lights are fantastic. I just replaced another set of fluorescent lights in my shop/basement with LED fixtures. bright and the 4K color temperature looks so natural. No flicker to drive you nuts also.
    Thanks for the pictures.
  4. Aug 26, 2018 #4
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Oct 22, 2011
    1,671
    319
  5. Aug 27, 2018 #5
    almega
    almega
    almega
    Mar 8, 2018
    52
    18
    Gender:
    Male
    Occupation:
    Maumee, OH
  6. Aug 27, 2018 #6
    deverett
    deverett
    deverett
    deverett HMEM Supporter
    Sep 6, 2007
    1,092
    214
    Occupation:
    Retired
    Skibbereen, West Cork
    I used a pair of B&Q (British DIY store) LED lamps, one on either side of the column.[​IMG]Original lights (when the machine was quite new). Haven't got a pic of the Angel Eyes, but the light is similar to Almega's.
    The LED lamps were OK in the beginning, then I mounted two concentric Angel Eyes - similar to eBay 162467028654 - around the quill. The original lamps are quite dim in comparison, but they have been left in place.
    Some have said the rings create shadows round the work, particularly if the head is low. I haven't found this.
    The Emerald Isle
  7. Aug 28, 2018 #7
    lemelman
    lemelman
    lemelman
    Apr 2, 2012
    54
    8
    I tried one of these a few years ago, but the detritus thrown up when milling caused several LEDs to fail. I found another type that incorporated a sort of protective lens and that has worked well ever since.
    I use a redundant 12V power supply which works just fine.
  8. Aug 29, 2018 #8
    Cogsy
    Cogsy
    Cogsy
    Well-Known Member Staff Member Global Moderator
    Jul 30, 2012
    2,501
    721
    Gender:
    Male
    Perth, Western Australia
    I use cheap waterproof strip LED's from eBay - like these ones LINK. I've had them for a couple of years and they've been excellent. The main advantage is you can cut and join the strips (there's a connection point every 3 LEDs) so you can create your own shapes or do a double run, etc. plus, you get enough LED's to light up a couple of dozen mills. I have 5 strips under the bottom of the head, 1 across the back and 2 down each side (my 'DRO' gets in the way for one across the front). Eventually I'll install them in other places around the house and shed when I get the time. They're powered by a cheap wall wart and because I'm only running a few and not the whole 5M length it only needs a low power one.
    JC54 likes this.
  9. Sep 1, 2018 #9
    rodw
    rodw
    rodw
    Dec 3, 2012
    1,123
    334
    [​IMG]
    My Angel Eye headlight surround. Still going strong after about 5 years
  10. Sep 1, 2018 #10
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Oct 22, 2011
    1,671
    319
    Agree I use the same thing. LOVE it,clear and no shadow
  11. Sep 6, 2018 #11
    canadianhorsepower
    canadianhorsepower
    canadianhorsepower
    Oct 22, 2011
    1,671
    319
    the power supply is a simple wall unit and I used heavy duty 2 way tape to hold it in place.
  12. Mar 15, 2019 #12
    truckeic
    truckeic
    truckeic
    New Member
    Oct 2, 2018
    1
    0
    Gender:
    Male
    hickory NC
Share This Page
