- Jan 4, 2011
- 1,332
- 343
How would I accurately measure an internal taper? This came up as I was trying to determine the taper inside the headstock on my South Bend lathe. It is either #5 or a SB special taper. I was thinking about making an adaptor to fit 5C collets instead of the external holder I now have.
I have the usual dial indicators but there is no way to get the large dial indicator inside the hole and the indicator with the arm only has a very limited range. I have a digital scale on the X axis so I can move the carriage a known distance but I don't know how the measure the distance on the Y axis. If I decide to make the adaptor I would want to set the compound at the correct angle to fit the taper. The only thing I have come up with is to make a lever type arm to fit in the hole and measure the distance that the lever moved on the other end. Not a must have but I have been wondering how this could be done.
Gordon
Gordon
